B18a Hard start when engine cold... help?
Old Jun 30, 2009 | 03:12 PM
jimbo89's Avatar
Default B18a Hard start when engine cold... help?
So I went home for my week long summer break and drove my car for the first time in six months. I put sta-bil in the tank before I left it and it was not driven during the whole six months I was gone. While home I drove it 2 days and it ran perfectly and started fine and everything was good... Buuut on the third day when I went to start it I had to crank it about 5-10 seconds for it to fire. Once it warms up it runs perfectly and will start fine, its only hard starting when the car has sit for 2 hours or more... I put fresh gas in it and I replaced the plugs because they were destroyed and needed it anyway. I also checked the timing and it was right on. I can hear the fuel pump prime when I turn the key on but I don't know if it is building pressure or if I have another problem. I am thinking its fuel related but I didn't have time to test anything before my break was over and had to fly back to wyoming. I wont be home again till september but I cant stop thinking about this problem...
I am hoping someone has had the same problem but if not does anyone have a thought of what it could be? Oh and its a 90 civic hatch with a b18a1. thanks.
Old Jun 30, 2009 | 08:00 PM
ek-g6's Avatar
Default Re: B18a Hard start when engine cold... help?
I had a similar problem, and turned out the fuel filter was clogged. When was the last time fuel filter was changed?
Old Jul 1, 2009 | 04:36 AM
jimbo89's Avatar
It has probably been a year or so since I have changed the fuel filter.
Old Jul 1, 2009 | 12:55 PM
Danielsb20crx's Avatar
check the comperssion i had a a1 do this to me once its warmed up it didint have a problem did a leak down test and #1 piston ring was bad
Old Jul 1, 2009 | 04:11 PM
jimbo89's Avatar
hmm, I really don't see how low compression on one cylinder could cause it not start like mine does... I would think it would at least fire on the other cylinders when it cranks... But its easy to check so mine as well. thanks for the input.
Old Oct 3, 2009 | 03:55 PM
jimbo89's Avatar
so I got to go home last week and i put a fuel pressure guage on and replaced the filter. Its around 40psi. I am still woundering whats wrong...
Old Oct 3, 2009 | 04:10 PM
alscrx's Avatar
Could be a cold start compression problem. Those couple cranks help it build compression then it'll fire.
You'll notice summer days are a little easier to start but still not gonna start like normal.
Do a leak down test for sure.
Old Oct 3, 2009 | 08:05 PM
jimbo89's Avatar
it was an overnight thing though, it went from starting in 1 crank to taking 10 seconds to start (which feels like forever) I am thinking it would be some sort of electrical problem but when its hard starting and it fires it seems to pop out the intake for a second like its a timing problem, but i checked timing and it is fine. I am back in wyoming though and have 3 months to think about it before I see it again... still like to know if anyone else has this problem??
Old Jan 29, 2010 | 07:43 AM
jimbo89's Avatar
So I checked compression on all 4 and they were all right around 185 and I didn't see the gauge drop at all over a 5 minute period... I did a little test to check spark by squarting some starting fluid into the intake before cranking and it fired right up, so I am thinking I still have a fuel problem. My fuel pressure guage says there is 40 psi on the outlet of the filter. So my question would be do the injectors have a sensor in the distributor to tell them when to fire, since my engine is obd-0 and I am pretty positive it doesn't have a crank position sensor? Please any input would be helpful...
Old Jun 16, 2011 | 05:07 PM
Scherer280's Avatar
Sounds like the same problem I am having...
Old Jun 16, 2011 | 06:58 PM
jimbo89's Avatar
So I ended up fixing my starting problem when I got back from school a year or so ago. I had another car to drive and I was running out of ideas of what could be wrong because I got a set of injectors from pull-a-part and put those in and nothing changed. So I started unwrapping the engine harness and checking all wires, connections, and grounds and found a few problems that I was kinda pissed to find (I didn't do motor swap so I wasn't mad at myself) But there was a broken temp sender wire and the oxygen sensor wire (single wire obd-0 O2 sensor) wasn't looking to hot either so I repaired that wire too. I then added a few grounds that ground the motor to the frame in a few spots, mainly the main ground for the engine harness where its attached to the engine, which was by the thermostat on my car. After doing these few things I re-wrapped my harness and the car fired up like it used to. This car is my DD and I work 7 days a week and it hasn't given me a single problem ever since I fixed the starting problem. Hope you can find your problem, but I kinda doubt it is going to be the same as mine, I think my problem was rather unique and doesn't happen to everyone, or anyone else for that matter...
hondagirl2007
Honda CR-V & Element
Jun 29, 2017 07:29 PM
bsballboyjk
Oct 4, 2007 10:19 PM
zach1288
Nov 16, 2006 12:20 PM
djwest24
Oct 24, 2005 07:44 PM
yusoslo
Sep 28, 2003 12:29 PM
