B18C5 Crank Pulley Clearance
Does the crank pulley on the B18C5 without modification to the frame rail fit on a 1990 Dx hatch? Just trying to determine which pulley to buy. I want to retain the factory a/c and obviously the alternator but I want a stock looking pulley. Just wondering if there is an alternative if it doesn't fit without denting in the frame rail.
Here are the specs:
Mounts: Hasport 2011-2012 (latest design revision), click for image
block: b18c
crank pulley: b18c5, unmodified
clearance between bottom of crank pulley & D-CRX oem radius rod with suspension @ full compression (shock removed, everything else connected, upper control arm fully compressed against chassis): about 0.275"
I personally feel this is sufficient clearance. THe upper control arm should never bottom out against the chassis. So the clearance I measured is the "theoretical" minimum (using my setup), assuming the upper control arm can bottom out against the chassis.
