D15 no start
Old Jun 28, 2009 | 11:18 AM
90Rexx's Avatar
Default D15 no start
I got a90 civic with a 1.5 it cranks but doesn't start. When u crank it the intake backfires. Compression is 150 across the board and I have spark and fuel. Timing is good! Help please! No cel either
Old Jun 28, 2009 | 11:32 AM
TuFoSx's Avatar
Default Re: D15 no start
you may have jumped a tooth on timing, check your t-belt for any missing teeth, also make sure your spark plug wires are in the right order...wouldnt hurt to check your cap an rotor either, good luck
Old Jun 28, 2009 | 06:01 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Check to see if your dizzy is 180* out of phase? Also have you double checked your spark plug wires for correct order? Double check camshaft timing... also try to move the dizzy back and forth while cranking to get her to fire. Sounds like timing is off or the dizzy is not in the proper place for base timing.
Old Jul 3, 2009 | 06:23 AM
90Rexx's Avatar
ended up being a loose set screw in the dizzy's rotor....
ek_ct
Aug 24, 2015 03:58 PM
playa24vtec
19
Nov 5, 2013 09:19 AM
tarheelsoldier
Mar 15, 2007 08:46 AM
RenzoDaPlayboi
Nov 3, 2006 10:01 PM
importlegions
Jul 29, 2004 11:28 AM
