i have a small crack in my turbo
Old Jun 28, 2009 | 09:43 AM
tsdneil's Avatar
Icon2 i have a small crack in my turbo
will this effect the performance? the crack is very small and it goes all the way through to the other side of the wastegate flapper valve. it does not not go all the way to the flange on the side that mounts to the manifold. heres some pics.
Old Jun 28, 2009 | 06:11 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: i have a small crack in my turbo
Throw that thing away it is garbage, unless of course you want a cool paper weight!
Old Jun 28, 2009 | 07:53 PM
srmofo's Avatar
gawd damn that thing is small!
Old Jun 28, 2009 | 10:27 PM
blinx9900's Avatar
wow, internal wg is nearly larger than the compressor!!!!!!
Old Jun 28, 2009 | 10:36 PM
OneBanzai's Avatar
so small !!
Old Jun 28, 2009 | 11:00 PM
recovery69's Avatar
it's cracked because it's an ebay turbo
Old Jun 28, 2009 | 11:42 PM
traxxasx's Avatar
What a retard its a 1g talon turbo 14b. Its a very nice turbo for single cam. Were making 220 on a complete stock single cam on 9lbs. Now we got a boost controller were going to up the boost. Its a DD car in an ef hatch and it pulls real hard.
Anyways the td05h is notorious for cracking exhaust housing where the WG flapper goes. Ours is cracked all the way to the flapper but holds a consitant 9lbs. You can have somone weld it to prevent further cracking, or you can just run it. Just have a boost cut off for saftery incase it does spike.
Old Jun 29, 2009 | 03:27 AM
blinx9900's Avatar
Your a moron, thats clearly an OEM turbo...
Old Jun 29, 2009 | 04:19 AM
2point2's Avatar
Blown turbos are excellent tools for mocking up a custom turbo setup.
Old Jun 29, 2009 | 08:02 AM
bacalhau16's Avatar
14b is a pretty nice turbo for a single cam motor. Easy to find, cheap, and matches well for a cheap DIY turbo setup.
That crack doesnt look serious at all. I agree, weld it, or just keep running it like it is. Shouldnt be a problem.
Old Jun 29, 2009 | 10:24 AM
tsdneil's Avatar
thats funny because if you look on the bottom portion of the wastegate actuator there is a mitsubishi symbol because it is a genuine mitsubishi heavy industries turbo.
not saying anyone here is wrong about the type of turbo it is, but i thought it was a 16g from an evo III?
Old Jun 29, 2009 | 12:07 PM
blaze the chemi's Avatar
I had a crack around the wastegate flapper on my greddy 18G. Who knows how long that thing was there, but I still put it on after knowing about it. I'm sure you could find another one cheap.
There must be a flaw with the cast or location of the flapper because it is a common problem.
Old Jun 29, 2009 | 06:43 PM
tsdneil's Avatar
it seems like a bad design to me. there isnt much thickness to the iron there, and on top of that, my turbo is ported and clipped. i guess that made it even thinner and more prone to cracking.
98lsdc
Oct 15, 2012 12:52 PM
dont_tri
Jul 1, 2008 04:40 AM
allmotor_dm
Jan 24, 2006 06:07 PM
b00stedbyFastrax
May 11, 2004 02:55 PM
jdmtegxsi
Jan 23, 2003 08:23 PM
