fuel pump relay
Old Aug 21, 2002 | 12:59 PM
ludelvr's Avatar
Default fuel pump relay
Can someone post up that picture of how to hook up the relay for an inline fuel pump? Thanks, I tried loooking for it, but can't find it!
Old Aug 21, 2002 | 01:10 PM
Cramerox's Avatar
Default Re: fuel pump relay (ludelvr)
artturbo's diagram
Old Aug 21, 2002 | 01:17 PM
zcivic91's Avatar
Default Re: fuel pump relay (Cramerox)
wat does this diagram mean?? im goin to get an inline upmp..i dont undestand wat the diagram is of or means??
also why not just let it run wit 12v and have constant pressure?? is it bad for the motor?
Old Aug 21, 2002 | 01:41 PM
Brian_92GSR's Avatar
New User
Default Re: fuel pump relay (zcivic91)
Because it needs to turn on and off with the regular fuel pump so that it only runs when the car is running. The power wire for the inline pump needs to be bigger than the power provided by the signal wire, so a relay is used.
Old Aug 21, 2002 | 03:27 PM
Etylorcen's Avatar
Default Re: fuel pump relay (Brian_92GSR)
I think he means where is the relay to tap. Its in the drivers side kick panel. I dont have my digi cam but ill try and find you a pic.
Old Aug 22, 2002 | 10:54 AM
ludelvr's Avatar
Default Re: fuel pump relay (Etylorcen)
Thanks guys!!
Old Aug 23, 2002 | 04:14 PM
GsrSdn's Avatar
If you find a pic of where this relay is id like to see it, might be causing a problem with my car.
Old Aug 23, 2002 | 05:40 PM
intekragsr's Avatar
Default Re: fuel pump relay (GsrSdn)
its a grey box half the size of a box of cigarettes under the driver side dash closer on the door side. its mounted by a small bracket. Tap the red wire of the fuel pump to pin 7 i belive.
hondaluver12
Jan 30, 2012 02:37 PM
Lmgrcivic
Apr 7, 2010 01:30 PM
ludelvr
Mar 2, 2005 08:11 PM
insomniac791
Jan 22, 2004 04:23 PM
