Transmission & Drivetrain Gearboxes, Differentials, Clutches
can you use motor oil on your transmission
Old Jun 25, 2009 | 07:48 PM
enoker001's Avatar
Default can you use motor oil on your transmission
so my mechanic told me that u can use motor oil on your tranny and i know that sounded strange so i wanted to make sure has anybody ever tried that
Old Jun 25, 2009 | 08:40 PM
stevenDAtegra's Avatar
Default Re: can you use motor oil on your transmission
You can and honda has also said you can. I run nothing but syncromesh friction modified but it's all opinion. The GM is part synthetic I hear so it doesn't break down like the motor oil would, but in a transmission I would assume it would still take a lot of miles compared to in an engine
Old Jun 25, 2009 | 11:09 PM
MFactory's Avatar
Honda transmissions were originally designed to be run on motor oil, so the answer is yes, you can. This is also the reason why you MUST NOT run GL4/5 Synthetic Gear Oil in your Honda transmission (i.e 99.9% of performance gear oils on the market) as it is too thick. You must stick to low viscosity transmission fluid.
However, motor oil lacks the additives required for longevity, hence why Honda released their custom transmission fluid to meet the requirements (MTF).
The GM/Pennzoil are also very good transmission fluids to use, but I personally use/recommend Torco MTF.
91grape
21
Jul 31, 2012 11:48 AM
EM2_PLo
Honda Civic (2001 - 2005)
14
Apr 21, 2010 09:28 PM
ApolloSpeed
38
Mar 13, 2006 11:22 AM
xstalkrx
Oct 12, 2003 05:09 AM
wizzards581
12
Mar 6, 2003 11:15 AM
