Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
I need A diagram
Old Jun 25, 2009 | 07:27 PM
speed_demon018's Avatar
Default I need A diagram
I need the under the hood diagram for a 2002 acura tl non-type s and i am unable to find one
Old Jun 25, 2009 | 07:36 PM
Default Re: I need A diagram
the fuse box under the hood i am trying to find the blower motor relay
Old Jun 25, 2009 | 08:58 PM
conme's Avatar
what wrong with the car?
Old Jun 25, 2009 | 10:09 PM
well the blower motor worked and then went back out to start it and it didnt work any more
Old Jun 26, 2009 | 01:59 PM
Targa250R's Avatar
be professional
Your problem is either a bad blower motor power transistor block, a bad blower motor, and/or a melted plug on the blower motor wiring harness (frighteningly common on '99-03 TLs). All of these are located under the dash on the far passenger side.
Old Jun 26, 2009 | 11:16 PM
how do you tell if the resistor is bad
Old Jun 29, 2009 | 12:52 PM
mugen88crx's Avatar
it's either the blower motor transistor/resistor or the blower motor sub harness... there is a bulletin on this issue. check with your local dealer... the sub harness is cheap, transistor not so bad. if the dealer is nice they can print you a copy of the bulletin... if not let me know, i work for one.
Bulletin # 06-006 "Blower Motor Does Not Work"
Old Jun 30, 2009 | 01:26 PM
it was the connector it was melted thanks for the help
James Blair
Honda Civic (2006 - 2015)
Mar 17, 2013 05:04 AM
tien285
Acura TL, RL & ZDX
Oct 22, 2012 04:13 PM
geezel81
Mar 22, 2008 06:27 AM
jdadams12
Sep 11, 2007 08:51 AM
daidilus
Dec 10, 2004 04:16 PM
