unknown wire help passenger side plug
Old Jun 24, 2009 | 07:25 AM
Rease3's Avatar
Default unknown wire help passenger side plug
where does this wire go? i have no idea
Old Jun 24, 2009 | 09:02 AM
Rease3's Avatar
Default Re: unknown wire help passenger side plug
bump for an answer
Old Jun 24, 2009 | 09:08 AM
dephtone's Avatar
What color is the wire? It's a hard picture to see anything in.
Old Jun 24, 2009 | 09:26 AM
Rease3's Avatar
its a gray sheilded wire what pin does it go to and what is it for?
Old Jun 24, 2009 | 09:35 AM
jlicrx's Avatar
if it is going into the pin on the connector next to the brown/black, it should be for the O2 sensor - at least that is what it is from the factory and should be a white wire
Old Jun 24, 2009 | 10:03 AM
Rease3's Avatar
i have not repinned the harness and it was hooked up like stock so it goes to the o2 sensor. under the gray cover it is a white wire.
Old Jun 24, 2009 | 10:11 AM
Rease3's Avatar
do i not need it if im converted to 4 wire o2? i have o2 disabled in crome
Old Jun 24, 2009 | 10:22 AM
dephtone's Avatar
If you are converting to obd1 you won't need the gray shielded wire, just the 4 wires that come from the conversion harness.
Old Jun 24, 2009 | 10:27 AM
Rease3's Avatar
cps wires c1 and c2 on the dizzy harness my colors are black/yellow and blue/yellow what goes to what one?
Old Jun 24, 2009 | 10:49 AM
jlicrx's Avatar
C1 should be blue/green and C2 should be blue/yellow - if they don't match, about all you can do is to just hook them up one way and if you get a code 9, switch them
Old Jun 24, 2009 | 05:08 PM
Rease3's Avatar
ok when it start it sounds like its dying. if i hit the gas it bogs out. dont have charge pipes hooked up. 3 bar map sensor throwing 3 codes. code 6,7,10. should i re run the wires from the pin to the plug or what should i do?
chrismanis
Nov 6, 2014 12:07 PM
Da_1991
Nov 10, 2013 07:14 PM
KevronsEG
Mar 31, 2003 10:11 AM
nsxmatt
Aug 7, 2002 07:20 PM
