no radio reception
Old Jun 24, 2009 | 07:15 AM
myEM2civic's Avatar
Default no radio reception
Ok guys heres the issue. i thank you in advance.
i have an aftermarket headunit and the cd/aux work perfect. the radio portion, however, gets zero reception. what could be causing this? how do i fix it? sometimes when i get lucky i can play with the plug in the back or just all out shake it and it will come one beautifully for a few seconds..then fail. thank you.
Old Jun 24, 2009 | 07:54 AM
2slowEM2's Avatar
New User
Default Re: no radio reception
Check to see if the antenna connection is firmly connected in the back of the head unit. It shouldn't be "stuck" in there but it shouldn't slip out easily.
Old Jun 24, 2009 | 08:16 AM
myEM2civic's Avatar
thank you, i just went outside and check that, i also followed the antenna all the way to the pillar where the antenna box is and it has no kinks and it everything is secure. still no reception.
Old Jun 24, 2009 | 10:39 AM
8520's Avatar
Did you power up the blue wire on the aftermarket honda harness?
Old Jun 24, 2009 | 10:49 AM
myEM2civic's Avatar
what does the blue wire connect to?
edit: went out to car...power antenna on the harness is wired up...i squeezed the connection a little bit to make sure it was tight, i can now hear just the slightest of reception, but still, a LOT of static. what does this mean?
Old Jun 25, 2009 | 08:37 AM
twentyhurtz's Avatar
the blue wire is the control lead to tell the power antenna to rise with in reception mode or radio.
Old Jun 28, 2009 | 01:26 PM
dj-t's Avatar
Antenna box in the pillar??
I assume that it is not powered if it is in the pillar. Or does it have a amplified box?
Try holding the antenna itself and see if the radio reception gets better or hold a ground to the outer shield of the antenna jack in the back of the radio.
If not then i will assume that the single wire inside the coax cable have broken inside the wire(probably at the ant jack).
Old Jun 29, 2009 | 10:28 PM
OEM92GS-R's Avatar
I had the same problem..just conected the blue antenna power wire and fm was working fine after that....
Old Jul 4, 2009 | 04:30 PM
jerzzehook's Avatar
New User
what kind of head unit is it
Old Jul 4, 2009 | 06:09 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car?
Make and model of HU? 94
Old Jul 7, 2009 | 06:24 AM
Marcd_206's Avatar
free bump
chsamia
Audio / Security / Video
Dec 30, 2010 08:09 AM
_HANS
Aug 26, 2007 02:32 PM
enefin
Dec 17, 2006 10:46 AM
djtony5
Apr 2, 2005 10:47 AM
TSAngry
Feb 26, 2004 01:16 PM
