Northern California North of Fresno
will i still pass smog replacing my b16a3 bottom block to a b16a2 bottom block???
Old Jun 24, 2009 | 06:05 AM
mynameizstitch's Avatar
Default will i still pass smog replacing my b16a3 bottom block to a b16a2 bottom block???
ok i got a CA barred b16a3 (1994 doch vtec del sol motor) in my 1993 honda civic. if i switch out my bottom block to a b16a2 bottom block w/ p30 piston and rods (jdm sir piston and rods), nippon racing piston rings, acl bearings, and arp rod bolts. i will be using my stock head and putting it back on this bottom block. my question is would i still pass smog with this bottom block in CA? since this would be on a usdm block not a jdm block just with jdm parts im assuming they wont be able to tell its the jdm piston and rods.
Old Jun 24, 2009 | 06:49 AM
InTeGrA_GsR's Avatar
Default Re: will i still pass smog replacing my b16a3 bottom block to a b16a2 bottom block???
it all depends how rich you're running.... about 6 months ago, i got my friends ek bard with a b16A2 99 EM1 motor and then 2 months later replaced it with a rebuilt jdm b16a block with a ctr piston and it barely passed... smog techs dont check for that kinda stuff trust me, i do that chit all that time... if u cant pass then hit me up =]
Old Jun 24, 2009 | 07:31 AM
my only concern is that if they read it as b16a2 they would say it's obd2 cuz my motor is ob1 right now being b16a3
Old Jun 24, 2009 | 07:53 AM
i doubt they will, like i said most smog tech wont even look they'll just scan the bar sticker and then look that the engine for any mods then smog it... btw u get the muffler u needed?
Old Jun 24, 2009 | 08:52 AM
oneiro's Avatar
Depends on the tech. Some techs are finnicky then others, Do you have a really good cat?
running a higher compression will raise the nox level.
G L
Old Jun 24, 2009 | 10:31 AM
wouldnt they put in the vin# from the bottom block? if they do then it would read that it is a different motor wouldnt it? yeah i found a muffler already thanks tho.
im not too worry about the cat if it's bad. i can just get another one and weld it on if that is the issue.
Old Jun 24, 2009 | 10:54 AM
Most time if u have a sticker, ill just scann it instead of punching it into the computer, that takes too long... just go do it, where do u smog ur car at?
Old Jun 24, 2009 | 12:26 PM
integra_speed's Avatar
go to some cheap mexican shop. never fails.. and thsoe no pass no pay places. they WANT you to pass ;]
Old Jun 24, 2009 | 12:49 PM
i used to smog my cars at some vietnamese guy in modesto but i just moved up here to sacramento so ima have to find a smog place. will i dont have to smog for like another year or so. i just want to be safe for the long run.
Old Jun 24, 2009 | 01:39 PM
eg6style's Avatar
I passed smog in my car. Took me four tries though. Jdm itr pistons, 2 layer head gasket in a gsr. Tech just do a visual on the car and smogs it. Like integragsr said. They scan bar sticker and visual and smog.
Old Jun 24, 2009 | 02:26 PM
what did you do differently to pass it the 4th time? since you said it took 4 tries
Old Jun 24, 2009 | 03:08 PM
^slipped the tech a 100 to call it a day hahaha jk
Old Jun 24, 2009 | 04:35 PM
eg6style's Avatar
I double cat my car and place de natured alcohol. My car was running to rich. I was also running a jdm itr header too
Old Jun 24, 2009 | 05:01 PM
like i said if u cant pass it then lmk
Old Jun 24, 2009 | 06:41 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
What does your BAR sticker say?
Old Jun 24, 2009 | 09:23 PM
yeah i will let you know
DC2_R
Dec 20, 2009 09:23 AM
mynameizstitch
Jun 24, 2009 10:56 AM
DurrtyracingMIA
Oct 21, 2008 08:31 AM
D16SohcVtec
Jan 30, 2008 07:53 AM
trhoppe
Jun 5, 2006 03:24 PM
