apexi ws 2.25??
Old Jun 23, 2009 | 06:08 PM
djteggy99's Avatar
Default apexi ws 2.25??
hey guys i was just wondering i was thinking of getting the blox header and blox test pipe and there both 2.50 and i right now i have a dc sport header and stock cat which are 2.25.Well my apexi bolt up to the blox test pipe?
Old Jun 23, 2009 | 06:29 PM
thabao's Avatar
Default Re: apexi ws 2.25??
2.36".... I know cause i have that shitty thing in my basement
Old Jun 23, 2009 | 06:55 PM
djteggy99's Avatar
so im guessing it wont fit. i just wanna the header but i dont know if the stock cat will fit.
Old Jun 24, 2009 | 05:29 AM
thabao's Avatar
it'll bolt up doing worry. I have a JDM 4-1 itr header and a 2.5" test pipe bolted onto a ITR catback for daily use, so yours should work to.
Old Jun 24, 2009 | 07:06 AM
djteggy99's Avatar
mines a gsr car arent they just 2.25 and the itr cat is a 2.5? I think imma go ahead and get the blox header first.
Old Jun 24, 2009 | 08:37 AM
DC206R's Avatar
nope, gsr/ls are 2" i believe and ITR's are 2.25".
Old Jun 24, 2009 | 10:23 AM
iH8RICERZ's Avatar
If you're asking if it'll bolt up, it should. It'll just cause a bottle nose effect into your 2.25" apexi ws2 b pipe piping. I'm currently running the rmf narrow copy header (2.5") and a hollowed out jdm itr cat (2.5") which is connected to my apexi ws2 catback system as well. Of course if I wanted the most power out of my mods, I'd get a 2.5" exhaust system BUT living in CA, I don't want to draw any more attention.
Old Jun 24, 2009 | 11:34 AM
redflaredcrx90's Avatar
i have an apexi on my teg and it does fit
Old Jun 24, 2009 | 03:21 PM
I AM WEASEL's Avatar
2.36 is the ID, this exhaust and all of the other exhausts that are marketed as 60mm are (or can be considered depending on wall thickness) 2.5 inch exhausts, as metal tubing is measured by OD and wall size. So, with standard exhaust tubing being 16 gauge (.065) 2.5-(.065x2)=2.37, which when converted into milimeters is 60mm which when converted back is roughly 2.36. The K-teller and SMSP exhaust tubing kits that are marketed as 2.5(OD) inch have an ID of 2.37 like the majority of the aftermarket exhausts on the market.
Old Jun 24, 2009 | 04:48 PM
djteggy99's Avatar
well today i bought the blox header which are 2.5 and the inlinefour.com flange and gasket where its 2.5in/2.25 out which would bolt up to my cat which is a 2.25 is this alright too?
Old Jun 24, 2009 | 05:41 PM
djteggy99's Avatar
is the setup i bought alright?
Old Jun 24, 2009 | 06:08 PM
thabao's Avatar
Yup!
Old Jun 24, 2009 | 06:27 PM
djteggy99's Avatar
thanks lots guys
Old Jun 24, 2009 | 06:31 PM
thabao's Avatar
But, you need a better exhaust haha. I dont like apexi
Old Jul 2, 2009 | 02:32 PM
djteggy99's Avatar
okay i got my blox header today and noticed its way longer then my dc sport... and it passes my cat were the header and the cat bolts up. Can anyone tell me whats wrong do i need a test pipe?
Old Jul 2, 2009 | 07:50 PM
thabao's Avatar
Oh, so you got the HYtech replica, yeah then it's correct that it goes past the cat. You will probably have to cut the Tri flange off the exhaust and weld on a flange that will fit the header. But if theres a gap between the header flange and exhaust flange, you could make a tiny adapter like thing to make it fit.
Old Jul 2, 2009 | 08:17 PM
djteggy99's Avatar
i have a 99 gsr is there any other way to use this header without cutting or welding. I dont wanna mess up my cat back system like just buying an catback that is an 2.5 and will direct fit the header?
Old Jul 2, 2009 | 08:23 PM
djteggy99's Avatar
well okay i was reading on jhpusa they have a blox test pipe witch well adjust to any length to fit any header? Well this work for this header and whats the up and downs of using a test pipe.
Old Jul 2, 2009 | 08:25 PM
thabao's Avatar
Does your catback go past the header mounted?
Old Jul 2, 2009 | 08:32 PM
djteggy99's Avatar
the blox the length is the exact as my dc header and cat together which is better long.
Old Jul 2, 2009 | 08:37 PM
djteggy99's Avatar
well i think its almost that long
Old Jul 2, 2009 | 08:39 PM
thabao's Avatar
Pictures is worth a 1000 words get a pic that will help ha
Old Jul 2, 2009 | 08:46 PM
djteggy99's Avatar
yeah i dont know about a test pipe i think a testpipe would solve this problem. Never used one can yall tell me the good and bad of using a testpipe?
Old Jul 2, 2009 | 09:30 PM
jdm_bones's Avatar
Get an after market 2.5 CAT, the weld on the correct flanges, and make it the right size.
Old Jul 2, 2009 | 10:12 PM
djteggy99's Avatar
probably gonna end up selling it or trade it for a mint itr header.so anyone with an itr header holla at me haha.
osubuckeys
Apr 15, 2010 09:09 AM
djteggy99
Jul 1, 2008 07:04 PM
slooogsr
Jun 28, 2004 01:04 PM
CptCorN
Jun 29, 2003 06:23 PM
