b18b1 turbo build question
Old Jun 23, 2009 | 05:00 PM
HUGATO2002's Avatar
Default b18b1 turbo build question
Hey guys wuts up? I have a lsblock with wiseco 9:1, eagle rods, new timing belt, water pump arp main bolts, acl bearings, blockguard, new gaskets all over, arp headstuds, briancrower springs n retainers... the rest of the head is all stock...I was wondering if im able to push it to 375 to 400whp..... also would i need to add briancrower stage 2 cams? or the stock would b fine? please i need ur help... thanks a lot!!!!!
Old Jun 23, 2009 | 05:07 PM
94 ls-r's Avatar
Default Re: b18b1 turbo build question
Gonna be hard to get 400 out of a stock head. It can be done but a mild port might be needed. What turbo you plan on runnin? Pump gas?
Old Jun 23, 2009 | 09:52 PM
OoAreyuloO's Avatar
you sir will need bigger injectors and like ^^ said mild port and cams might get you near
as well as the tune and gas
Old Jun 24, 2009 | 08:40 AM
DC206R's Avatar
Forced Induction Forum. =] Check there. I'm sure you'll find your answer.
Old Jun 24, 2009 | 02:12 PM
HUGATO2002's Avatar
yes pump gas... 750cc injectors, fuel pressure regulator... in the future an manifold and throttle body etc... I was told that a garrett t3/t4 57trim would be ok... But im new to turbo set ups... so i need some help
Old Jun 24, 2009 | 02:57 PM
94 ls-r's Avatar
Just be sure to get good tune!!! The tune is everything!
Old Jun 24, 2009 | 07:17 PM
jhammond_82's Avatar
Reject Papi
agreed^
Old Jun 25, 2009 | 06:07 AM
Jdm Fernan's Avatar
New User
agreed^^ AEM EMS
gwarfare
Dec 23, 2011 11:23 AM
spoon93
Jun 22, 2011 01:41 PM
sleepydb8
Sep 24, 2010 07:03 PM
Sleeperzzz95
Mar 12, 2010 08:29 PM
lostsk8erchik
Feb 9, 2010 08:49 AM
