6th Gen Electrical Problem Need good diagrams
Old Jun 23, 2009 | 01:42 AM
BoorishId's Avatar
Default 6th Gen Electrical Problem Need good diagrams
First of all its a 2001 couple LX 4cyl
So my accord started throwing a CEL p0560 which translates to low backup voltage to the PCM. Well the wire that sends the backup voltage is yellow white with silver stripes. And it is connected to fuse 13 clock/backup located in the passenger side fuse box. Anyways so the clock is working just fine, i found the white yellow wire connected to the PCM tested it no voltage! Next i unplugged connector b from the fuse box. The white yellow wire is located in that harness i tested the continuity from the fuse box to the white yellow wire in the PCM harness it is good, for some reason it wont carry voltage though. I even took some alligator clips and connected a 9v to the fuse box then tested the voltage at the PCM harness still nothing. I am thinking i may just need a new fuse box but id like to test some other stuff first. Does anyone know where to get really detailed wiring diagrams because the haynes book sucks. Id like to be able to trace the whole yellow white circuit.
Old Jun 24, 2009 | 06:49 PM
Targa250R's Avatar
be professional
Default Re: 6th Gen Electrical Problem Need good diagrams
Just buy the Helm factory service manual:
http://www.helminc.com/helm/product2...EGR8D7PPF70E41
and/or the Helm electrical troubleshooting manual:
It's the best money you can ever spend on a vehicle if you intend to repair it yourself.
Piracy is theft, and I hate thieves.
Old Jun 25, 2009 | 04:55 AM
billyrusa's Avatar
I have attached the related diagrams for the model you questioned. Hope these will help. I did not find any YEL/WHT wire. I only found WHT/YEL wire witch connects the VBU pin of PCM with #13 fuse in passenger side.
Good luck.
File Type: pdf
File Type: pdf
File Type: pdf
My 93 accord
Sep 29, 2016 11:20 AM
(760)doogie
Jul 9, 2007 04:20 PM
HondaHemi
Nov 27, 2006 04:38 PM
hatchinprogress
May 2, 2006 10:52 AM
ogdogg16
Audio / Security / Video
Jan 14, 2003 09:39 PM
