Understanding Ignition maps fuel maps
When I drive on the highway in my sister's Volvo S60, I carefully watch the computer and see the instantaneous fuel economy. Its peak torque surprisingly is 1500rpm which at 55mph, is the speed I'm going at on the highway. Because it's at its peak torque at that speed, when climbing grades on the highway, I don't have to downshift. So I use cruise control and have the car maintain 55mph while in 5th gear w/torque converter locked up. So if I'm on a flat portion of highway, computer says something between 35mpg-42mpg, on a down grade it can go up to 99mpg especially if DFCO is into effect but when I go up a grade, the instantaneous MPG drops to usually about 27mpg but sometimes as low as 20mpg! So I'm wondering, since the car is maintaining its RPM and MPH, the only thing that can be changing is the throttle body, the ignition and fuel timing and amount, right?
So with the above in mind why would the fuel economy go down when going up a grade and improve on the flat or on slight decline? The things I can think of is more air is getting into the engine b/c throttle plate is fully open which means more fuel, the ignition timing is being retarded and the air-fuel ratio is going from 14:1 to 12:1 possibly.
Any thoughts on this? But what exactly is preventing the engine from getting the same economy on a grade compared to flat road? Only thing I can think of why the above happens is because the engine would knock otherwise??
You need more hp from the engine to go up a grade than down or flat- thus more air and more fuel. Just because an engine is operating at an rpm does not mean that at that given moment it is putting out a certain amount of power. It take a load on the engine to make the power possible at any given RPM to move the car- thus with the car moving down the highway on a flat or downward slope you only overcoming the coefficient of drag and static friction between the road and the tires- this amount of fuel that is taken to maintain the vehicles speed is relatively minimal, but as you increase speed you also increase the amount of air the vehicle is displacing and the rate that the friction between tire and road must be overcome- this also uses more fuel air- but at the same time if the car does this difference at a rate similar at the slower speed then it will not lose "mpg". Going up a grade you are putting a load on the motor greater than you had before when you were moving the car across the ground or downward slope- thus you need more power to overcome not only the friction of tire to road and drag, but also the weight of the car- (degree of slope x acceleration of gravity x mass of car) plus the weight of the car intially- this equals out to be greater than what it had taken to move the car on a flat plane
Long story short you go up hill your cars weight increases thus greater load on your motor needs more fuel and air- less mpg
Go down hill gravity works opposite for you and your cars inertia/weight overcomes its coefficient of static friction with the ground PINE DERBY style and the thing uses no more fuel than is needed to idle along at a given rpm.
Go to engineering school if you are truly intrigued by all of this- then you could map it out on your own!
load changes. you can hold 2000 rpm which will keep a certain mph unless your tires are spinning. when you go uphill, the load increases to maintain 2000rpm at whatever mph that is. when you go downhill, the load decreases to maintain 2000rpm at whatever mph that is.
I thought I covered that, we already know the load increases but just because the load increases, it doesn't mean it uses more energy. If you put a fan on full power and then slow the fan blade down, it's not like it's going to use more electricity than if you had no fan blade altogether, though you might end up spinning the motor far too fast since there will be no load.
your gas mileage is not going down because of more air... well, it is because you're going to open the throttle plate - which in turn will up your manifold pressure - which in turn will require more fuel - which in turn your gas mileage goes down. all this of course applies only if your cruise control is engaged to maintain that 55mph at 1500rpm.
there is less power at partial throttle vs. full throttle because of MAP. why does a car on 18psi of boost make more than a naturally aspirated engine? MAP.
ZebrasoHD
Engine Management and Tuning
Sep 29, 2018 06:37 AM
pooMan
Aug 25, 2005 12:20 PM
