JDM starter vs. USDM starter (accord)
Old Aug 21, 2002 | 07:32 AM
Charlie Moua's Avatar
Default JDM starter vs. USDM starter (accord)
ever since i changed my starter in my accord it makes a lite grind when i start it up some times. When i got the motor from NIppon it came with motor tranny and even had a starter. After about 6,000 miles i had to change it, so i just used my old one from my LX motor, and then i started hearing the lite grind.
---it only grinds about 1 of 10 starts and isn't a proplem but it just annoyes me.
*** people say that they also get grinds when they get a JUN or TODA flywheel... they say it grinds because the JDM flywheel teeth are slitly off my like .5mm or so, and the USDM startes will cause it to grind sometimes(is this true)
-^^^^^My car is an auto.
Old Aug 21, 2002 | 10:16 AM
Default Re: JDM starter vs. USDM starter (Charlie)
ttt
Old Aug 21, 2002 | 10:21 AM
KTeller8's Avatar
well you know your auto doesnt have a flywheel i dont believe?
not sure if there is a difference i got a full motor only.. and i got it fully loaded with all the wires and all kinds of stuff.. so i dont know..
Old Aug 21, 2002 | 11:48 AM
greensleeper's Avatar
Default Re: JDM starter vs. USDM starter (KTeller8)
sounds funky... I doubt they would design them differently.
Old Aug 21, 2002 | 12:59 PM
GimpyAccord's Avatar
Default Re: JDM starter vs. USDM starter (greensleeper)
Okay.. while my situation is different im having the SAME problem.
I have a manual car (was auto, but that doesnt matter now since you dont use a flex plate on a manual car obviously). And when i got the manual tranny it came with a starter hanging off it. All was well for 3 years until about 2 months ago my starter pukes and now about once out of every 10 starts i also get a grrrriiiind. I took off the starter and the ringgear looks fine
I got the starter from a NAPA, not honda.. could there be subtle differences in starters or are the acutators not popping out fully??? Dont know... I do know the starter i bought was a rebuilt.
[Modified by GimpyAccord, 9:59 PM 8/21/2002]
[Modified by GimpyAccord, 10:14 PM 8/21/2002]
Old Aug 21, 2002 | 09:28 PM
bmm89's Avatar
Default Re: JDM starter vs. USDM starter (GimpyAccord)
there is a dif. between the usdm auto and manual starters, but not sure about jdm but it makes sense that you may need the jdm part, see if you can find the part number, better yet, email that "JDM Andy" guy on ebay!!!
Old Aug 21, 2002 | 10:37 PM
H23 Power's Avatar
Default Re: JDM starter vs. USDM starter (bmm89)
you might have chipped/bent teeth on the flywheel/torque converter...
Old Aug 21, 2002 | 10:39 PM
Accord94DX's Avatar
you mean JAPANDY
Old Aug 22, 2002 | 03:49 AM
Default Re: JDM starter vs. USDM starter (F23 Power)
so let me get this right.... the starter attaches to the torque converter? I thought the T.Converter was located within the inside of the tranny.? please confirm
peterkemp47
Honda Accord (2013 - 2015)
Apr 4, 2024 04:07 PM
Salfior
Aug 11, 2018 12:47 PM
AccordH22aJDM
Oct 28, 2010 04:32 AM
92lsr
Jan 17, 2004 09:27 AM
Tommy_Gunns
Jan 24, 2003 03:08 PM
