2000 Honda Civic SiR
Old Jun 22, 2009 | 07:39 AM
preludequestion's Avatar
Default 2000 Honda Civic SiR
Hello,
My Civic is currently making the worst road noise in the world and I feel that it is making this noise due to a noisy, worn wheel bearing. Could this be the issue? I know that such an issue could cause this terrible noise, but how could one make sure this is in fact the issue? There is basically no tread left on the front tires, so that should not make the noise I am hearing.
Is it difficult to replace the wheel bearings on this vehicle, or would it be wise to take it to a mechanic to get the work done? Thanks for the information!
Old Jun 22, 2009 | 02:05 PM
Default Re: 2000 Honda Civic SiR
bump
Old Jun 22, 2009 | 02:12 PM
Ruben19's Avatar
get new tires & check the alignment. most likely one of the bearings is bad. they are press on bearings so you will need a press
Old Jun 22, 2009 | 02:26 PM
Former User's Avatar
Can you describe the noise?
If the front wheel bearing is indeed bad, you can save money by removing the knuckle yourself. Then take the knuckle to a shop to have the old bearing pressed out and the new one pressed in.
Old Jun 22, 2009 | 03:38 PM
kaotikvizion's Avatar
from my experience a month or so ago take it to discount tires or americas tires (same company) or pep boys ($15) & tell them what your hearing and they will tell you what it is. I had some bull s**t company *COUGH* express tire *COUGH* tell me it was a bearing that needed to be replaced. $240 bucks later it still made the noise so I took it to pep boys they rotated my tires & the noise went away! so tires could be it, mine were almost bald.
Last edited by kaotikvizion; Jun 22, 2009 at 03:39 PM. Reason: P.s. I immediately bought new tires
Old Jun 22, 2009 | 05:26 PM
hushypushy's Avatar
The first, free troubleshooting step you should take is to borrow someone else's wheels to rule out whether or not it's your wheels/tires.
Old Jun 22, 2009 | 05:27 PM
The noise is basically a constant noise, not really related to how quickly or not you are driving. No difference if you are turning I don't think. The tires are almost bald, and from what Kao was saying, I think I am in the same situation.
The seller told me it was probably a worn wheel bearing, but I am not completely sure. It is basically loud road noise - that might be the best way to explain it.
Elvis1977
11
Nov 12, 2012 04:46 PM
jdl
Apr 9, 2007 06:55 AM
clippernabeel
Honda Civic (2001 - 2005)
Mar 30, 2007 06:49 AM
Saintor
Apr 29, 2004 10:28 PM
REVolution
Mar 22, 2002 03:54 AM
