Valve cover gasket?
Old Jun 21, 2009 | 03:19 PM
brucepick's Avatar
Default Valve cover gasket?
I plan to do a valve adjustment soon - likely next weekend. '97 D16Y5, 169K miles.
Will I need a new gasket? Or do the old ones usually come off clean and go right back on?
I've already read and saved the thread at https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tech-article-valve-lash-adjustment-1305086/
Old Jun 21, 2009 | 03:21 PM
98civdx's Avatar
Master Detailer
Default Re: Valve cover gasket?
they can, if your careful you can normaly re-use it but i would replace it.
due to the fact its prolly the oe gasket and nver been replaced.
Old Jun 21, 2009 | 05:12 PM
brucepick's Avatar
"...but if it has around then 3k on the gasket I'd buy a new one." Huh?
You mean 300K or ??
Honda Bond? Is that a gasket sealer I get at the Honda dealership? Haynes sez use Sillicone RTV but maybe I need Honda Bond.
Old Jun 21, 2009 | 05:21 PM
ek-g6's Avatar
It would be much better just to buy a new one, but if your going to cheap route, you can get some high temp silicone.
Old Jun 21, 2009 | 05:27 PM
Thizzed Out's Avatar
No no I meant 3,000
your suppose to change it when ever you pull the VC off but I wouldn't change it if it was under 3,000 miles since that's pretty much throwing money lol I change mine a lot. Honda bond is used for a lot of things 1 of its uses is for the VC and yes you can get it at Honda, but sure you can use the Autozone stuff. I like to use OEM parts most of the time so that's why I recommended Honda Bond.
Old Jun 21, 2009 | 05:30 PM
ballisticej1's Avatar
Originally Posted by Thizzed Out
No no I meant 3,000 your suppose to change it when ever you pull the VC off but I wouldn't change it if it was under 3,000 miles since that's pretty much throwing money lol I change mine a lot. Honda bond is used for a lot of things 1 of its uses is for the VC and yes you can get it at Honda, but sure you can use the Autozone stuff. I like to use OEM parts most of the time so that's why I recommended Honda Bond.
Since when do you change a valve cover gasket every 3000 miles?
Old Jun 21, 2009 | 05:35 PM
Lol you dont... Change it when ever you pull the VC off.
Old Jun 21, 2009 | 06:06 PM
jdmcarboy2300's Avatar
naw u should definitely replace the vc gasket cuz most likely itll leak if the same one is reused
Old Jun 21, 2009 | 06:38 PM
dohcdelsol's Avatar
ive reused the VC gasket many of times wo any problems.
not til its about dry rotted will it leak and you gotta replace it.
but not everytime you remove it you gotta replace it.
Old Jun 21, 2009 | 06:46 PM
civic_driver's Avatar
When I adjusted the valves on my civic I reused the old one without any sealant and it doesn't leak.
Old Jun 21, 2009 | 06:54 PM
TOO MUCH TORQUE's Avatar
here is my take on it
when i did my valve adjustment, i re-used my valve cover gasket. after my first drive, i noticed oil seepage on the corner. what i did wrong was NOT tightening the valve cover bolts in 2 step tightening process and in a certain pattern. a good idea would be to first inspect the gasket for cracks and use a razor blade to scrape off old bond from the head.
Old Jun 21, 2009 | 07:19 PM
ej1love's Avatar
if its the honda gasket u dont have to change it every time, that is unless its done for.
Old Jun 21, 2009 | 07:48 PM
The following is the order and torque spec for the valve cover on a 96-00 civic. If you follow that, you shouldn't leak any oil when you reassemble.
Old Jun 21, 2009 | 09:00 PM
98civdx's Avatar
Master Detailer
^^ whats with the 30 min wait time to fill with oil?
Old Jun 21, 2009 | 09:14 PM
TheJGB3's Avatar
To let the Hondabond dry
Old Jun 22, 2009 | 11:54 AM
Yeah. I didn't include that part in the snapshot.
Old Jun 22, 2009 | 03:53 PM
brucepick's Avatar
Thanks guys.
Now I gotta get a decent torque wrench. For the valve adjustment AND the valve cover afterwards.
davidt1
Apr 4, 2012 06:44 AM
hdanewb
Jul 15, 2008 11:13 PM
rasinhell
Aug 8, 2005 01:00 PM
reignofchaos
Jul 27, 2003 01:33 AM
RicedREX
Feb 9, 2003 09:31 AM
