fog light problems
Old Jun 21, 2009 | 01:54 PM
edsonhp1991's Avatar
Default fog light problems
i got a 99 hatch and i installed depo foglights bout a month ago and they were working fine..but jus the other day they stopped working...all the fuses r good..grounds r good..and was workin fine for a while...but now i cant get em 2 work..any1 have any ideas or any1 had the same problem? alose i got power locks and an alrm put in bout 2 days b4 they stopped workin if tht would have anything 2 do with it
Old Jun 21, 2009 | 01:56 PM
6footmidget's Avatar
Default Re: fog light problems
check and see if your relay clicks, i had a bad relay with mine
Old Jun 21, 2009 | 01:58 PM
yea when i press it i here a lil click...tht means its bad?
Old Jun 21, 2009 | 03:20 PM
ek-g6's Avatar
seems like the relay is still good. Have you check the light bulbs?
Old Jun 21, 2009 | 09:15 PM
TheJGB3's Avatar
X2
Old Jun 22, 2009 | 07:34 AM
geebs's Avatar
My relay clicked, I assumed it was working correctly..
But my fogs never turned on. I checked every wire, hot wired the bulbs.. all good..
Found out the relay wasn't making contact..
Old Jun 22, 2009 | 07:44 AM
EG6KILIN's Avatar
my guys when out to just like that all he did was changed his fog light switch cause it smelled like it got fried after he changed it it worked again
Old Jun 22, 2009 | 12:04 PM
nah i havent checked the bulbs yet..but y would they both go out? there in the same circut? ima check the bulbs if they good then ill change the relay then switch..thnks
papi123
Honda Civic (2001 - 2005)
Aug 19, 2014 09:11 AM
clubef9
Lighting
Feb 21, 2008 01:26 PM
professorman
May 18, 2006 10:21 AM
anthonylee29
Jan 29, 2006 07:40 PM
