ej1 wont start
Old Jun 21, 2009 | 08:54 AM
ej1love's Avatar
Default ej1 wont start
ok i get cluster lights, but when i go to turn it all the way on it just clicks fast. but i can jump it and it starts fine. then when i kill it it wont wont start back. im chargein my battery now and noticed my neg terminal was a lil loose. i tightened it. what could it be?, the starter? and will a bad starter still start up when jumped? need help asap!
Old Jun 21, 2009 | 08:57 AM
d4rk13l4de's Avatar
Default Re: ej1 wont start
well when you dont have enough juice to your starter sylinoid it will just click, if anything get it running and take it to your local parts store they will test your battery and if its good the termanals are a cheap starting fix.
Old Jun 21, 2009 | 09:01 AM
ej1love's Avatar
yea thx, well it does run when jumped, and its on charge now... so if the starter was bad it wouldnt work when jumped either? just seein if its the battery or the starter.
Old Jun 21, 2009 | 09:04 AM
d4rk13l4de's Avatar
well it it starts when jumped then no its not your starter, its your battery not giving enough juice
Old Jun 21, 2009 | 09:07 AM
ej1love's Avatar
thanks darkblade, for the fast input... really appreciate it.
Old Jun 21, 2009 | 09:10 AM
Thizzed Out's Avatar
did you check your grounds? I had the same problem and it was my transmission ground that was loose.
Old Jun 21, 2009 | 09:13 AM
ej1love's Avatar
the only ground i messed wit was the one by the battery, it was a turn loose. idk, waitin for my battery to see if it will keep a charge...
Old Jun 21, 2009 | 09:20 AM
d4rk13l4de's Avatar
no problem man
Old Jun 21, 2009 | 01:33 PM
ej1love's Avatar
i guess my battery took a ****, it shows fully charged but wont power me up. could it be the altenator by any chance? im waitin to swap out my battery till tonight... its like 100 degrees out now.
Old Jun 21, 2009 | 01:40 PM
have it tested
Old Jun 21, 2009 | 01:46 PM
ej1love's Avatar
Originally Posted by Thizzed Out
have it tested
whats 'it'?
Old Jun 21, 2009 | 01:55 PM
6footmidget's Avatar
Originally Posted by ej1love
whats 'it'?
im sure he means alternator, but if your car starts when jumped, then i dont think its a bad alternator, cause your battery cant run off on its own without the alternator
Old Jun 21, 2009 | 01:56 PM
lol sorry i meant test your alternator, get it started again (push start i guess) remove the neg battery terminal and if the car stays running the alternator is good.
Old Jun 21, 2009 | 02:30 PM
ej1love's Avatar
good to know thx..
also good to know, thanks guys... hopefully this is a fix. (new battery)
Old Jun 21, 2009 | 02:39 PM
Benny-coupe's Avatar
The same problem happened with me and my friends eg6 this week ,both were battery problems ,Take out the battery ,check the terminals ,check if its full with fluid also ,a quick fix on mine was to top up the battery and give the terminals a sand down with some sandpaper ,
Both cars fired up first time
Old Jun 21, 2009 | 02:59 PM
what made you rule out the starter? does the motor crank?
Old Jun 21, 2009 | 03:16 PM
g230sport's Avatar
okay, a loose connection, or a bad battery will make the starter click like that...
id throw a battery in it, like a nice interstate from a local service station, not some duralast ****. and also hook your car up to an ammeter or vat machine, and see what kind of amperage its got while running, that would let you know if your alternator is bad.
chances are, if the alternator went bad, you killed the battery by driving it home, and draining the battery til it was dead.
so a new battery will get you running, unless your terminals are ****ed up. then have your alternator tested...
hope this helps
Old Jun 21, 2009 | 03:37 PM
hope this helps
x2 Good advice
Old Jun 21, 2009 | 04:27 PM
ej1love's Avatar
test your alternator, get it started again, remove the neg battery terminal and if the car stays running the alternator is good.
did this and it stayed running.
doing this tomorrow, the duralast was 70$. how much more is the interstate?
thx everyone...
Old Jun 21, 2009 | 04:46 PM
batt good
alternator good
wires good
I think its the starter, does the engine crank?
Old Jun 21, 2009 | 05:51 PM
g230sport's Avatar
an interstate mt 51 i believe it is for hondas is like 90 bucks my price, so probably like 110 bucks or so for a regular joe.
just stop by a service station in your area, most that carry interstate products have a sign or something in the window, or just ask them.
i happen to own an ej1 also, and im also a mechanic.
i wouldnt put a cheap duralast in my ride, but thats just me.
put a battery in it, whatever you want...
take it somewhere, and have the charging system checked out, or if you have a fluke or other ohm meter, you can put the neg on the neg post, and pos on the pos post, and it should be around like 14.2 while running if the alternator is working.
something like that i think. ive seen my pops do it when i worked with him and thats what he was telling me i believe.
anyways, hope this helps also..
John
Old Jun 21, 2009 | 06:11 PM
ej1love's Avatar
yea it cranks but u can tell theres no juice... tomorrow im gonna get a new battery and let them check out my alternator reading.
Old Jun 22, 2009 | 10:22 PM
d4rk13l4de's Avatar
its your battery man, i gaurantee it just repace the battery and the terminal too if there in bad shape. and you will be good to go
Old Jun 23, 2009 | 06:35 AM
ej1love's Avatar
yea it was the battery, swapped it out and it cranked right up...
ATS*Mark
Oct 5, 2019 05:01 AM
pgpunkguy
Jan 22, 2008 11:29 AM
ZexyAccord
Jan 9, 2006 03:34 PM
mingchi69
Jul 14, 2003 06:14 PM
Superhatch
Dec 24, 2002 02:36 AM
