please help me all info inside thanks
Old Jun 20, 2009 | 09:35 PM
925EKCOUPE's Avatar
Default please help me all info inside thanks
okay so i had a blown engine swapped it out now for a d16y7 money problems till i can get back anyways the sensor on the transmisson back got ****ed up only have 1 of the three inputs in anyways when i start the car its fine but the tach says im at 4k idle which im not and then when i press the gas it bogggs out what can be wrong i got the engine from a HAP in sac and i dont think its the engine just need some help so once again the tach says im at 4k idle and im not and the car boggs out at idle no check engine light and the sensor on the tramssiom is missin 2 of the three but the two dont go back to the ecu they go to two other senors that have no use in my car thanks
sorry i bit tipsy so sorry for the repeat lol
Old Jun 20, 2009 | 09:37 PM
Linked's Avatar
Default Re: please help me all info inside thanks
lol just cause your tipsy.
just because those 2 wires didnt lead to the ecu doesnt mean their not needed.
Old Jun 20, 2009 | 09:39 PM
925EKCOUPE's Avatar
could that really be the whole problem???? sorry im bbouts to go out and just wanted to throw it out and get some help no bullshit but thanks thats what i was thinkin
Old Jun 20, 2009 | 09:41 PM
Linked's Avatar
well it could also have to do with what engine you had previously,
im no tech specialist but some thing fit during the swap... some dont..
Old Jun 20, 2009 | 11:04 PM
R666_EK's Avatar
I would fix the problems you know you have. That sensor is the VSS and and converts the signal to your speed. The RPM signal comes from the distributor. I'm thinkin the distributor might be bad. Try swapping it for a known good one.
Old Jun 21, 2009 | 12:52 AM
Jimmy's Avatar
Global Moderator
https://honda-tech.com/forums/showthread.php?t=2407755
rtran19
Feb 8, 2010 08:55 AM
98silver-civic
Sep 28, 2009 05:46 AM
tenpercenter
May 23, 2006 08:32 AM
NyteCrawla
Nov 2, 2004 01:18 PM
4doorLX
11
Apr 5, 2002 05:52 AM
