s2000 alarm help **URGENT** PLEASE
trying to install a viper 5002 in a s2000 and having problems figuring out the power lock and unlock connection. It has a 7 pin harness with violent & a violet/black connected to a fuse. Please help
viper alarm harness has:
brown/blk
wht/blk
blue/blk
green/blk
violet & a violet/blk connected to fuse
If anyone can guide me to what wire goes where...I would very much appreciate it.
Thanks
brown/blk
wht/blk
blue/blk
green/blk
Thanks
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You car has reverse polarity door locks. And the small set back is that you three wires to control the keyless entry system. See the diagram
S2000 2000 -2009
KEY T-HARNESS IMMOBILIZER
N/A N/A HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
STARTER BLUE/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/RED (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 WHITE/RED (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) BLUE (-) @ HEADLIGHT SWITCH
PARKING LIGHTS ( + ) RED/BLACK (+) @ KEYLESS ENTRY MODULE, See NOTE *1
POWER LOCK PINK/BLACK (TYPE C) @ KEYLESS ENTRY MODULE, See NOTE *1
POWER UNLOCK YELLOW/GREEN and PINK/BLUE (TYPE C) @ KEYLESS ENTRY MODULE, See NOTE *1
LOCK MOTOR WIRE PINK/BLACK (+) @ KEYLESS ENTRY MODULE, See NOTE *1
DOOR TRIGGER BLACK/WHITE (-) @ KEYLESS ENTRY MODULE, See NOTE *1
DOMELIGHT SUPERVISION USE DOOR TRIGGER Requires Part #775 Relay
TRUNK RELEASE BLACK/YELLOW (+) Requires Part #775 Relay @ KEYLESS ENTRY MODULE, See NOTE *1
SLIDING POWER DOOR N/A
HORN ORANGE (-) @ KEYLESS ENTRY MODULE, See NOTE *1
TACH BLUE @ TACH TEST CONNECTOR, See NOTE *2
WAIT TO START LIGHT N/A
BRAKE WHITE/BLACK (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM WHITE (-) @ KEYLESS ENTRY MODULE, See NOTE *1
ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY, Standard on All Models TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 THE KEYLESS ENTRY MODULE IS LOCATED IN THE DRIVERS KICK PANEL BEHIND THE START BUTTON.
NOTE *2 THE TACH TEST CONNECTOR IS A 2-PIN BLACK PLUG BEHIND THE FUSEBOX UNDER THE HOOD,ON THE DRIVERS SIDE OF THE ENGINE COMPARTMENT.
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
It will be easier to use three relays to control the keyless entry to keep them isolated. Convert the viper alarm to neg output trigger by grounding the purple wire and using the blue wire and green wire to control the relays. Here is a diagram on how to wire up the relays. Use the 5 wire diagram. The switch will changed to factory keyless entry and output will be going to car.
http://www.the12volt.com/doorlocks/page3.asp#4w
S2000 2000 -2009
STARTER 2 N/A
IGNITION 3 N/A
KEYSENSE N/A
NOTES
dafuzzbudd
Audio / Security / Video
13
Oct 4, 2008 03:52 PM
