Need help with my EG. Please, Thanks for your time.
I'm having this problem with my EG. I was driving home from work and the whole interior just went out. My interior lights work, but the speed, rpm, gas, temp, and also my signal doesn't can someone help me. Someone ask me to check my VSS but I guess that's not it. Can someone please help. Thanks for your time.
Ok.... kinda figured that but in the interests of troubleshooting
Have they flickered on and off or are they just out? Have you done any work on the cluster or behind the dashboard recently? Any other work lately? Just trying to narrow it down
Yes I did took it apart and look at the back of it... I don't seem anything wrong with it... My brother has a EG just like mind I took his interior off and put it on mine. It does the same thing. I took my and put it on his and it work just fine. I don't know what's going on with it.
As mentioned by kirbyno1, check for a blown fuse. Everything that isn't working is protected by fuse 15 under the dash. Replace the current fuse 15 with a known good 10A fuse.
which one is the fuse 15? I'm lost... please help! I also check all the fuse everyone look okay.. still noting is working beside my interior lights...
I'm looking at the picture fuse box... where is the fuse that I'm suppose to look for and replace it? which one? they all look fine to me... when I look at them and I was making sure their the right one. 15 to 15 and 10 to 10 and 30 to 30. what should I do? replace them all?
sorry if this has already been said, check the dimmer switch (common on eg's). just tap it a couple of times or swap it with your brothers and see if that does it. update us if it does the trick.
No. the interior lights works and the head/tails lights work. Just the speed, rpm, gas, temp and also the signals doesn't work.
Hondogg
Sep 7, 2004 09:45 AM
