del sol a/c question
Old Jun 18, 2009 | 12:47 PM
bmd116's Avatar
Default del sol a/c question
i wanted to kno if i got a b series in the sol, can i use any b series a/c braket and compressor or only the del sol vtec bracket.
ok i now that i have that question out the way, i just wanted to kno if you could use the ac bracket even if the the torque mount was removed???
jus wanted to kno cause im about to get one but the person who had it said they shaved it off
Old Jun 18, 2009 | 05:43 PM
bmd116's Avatar
Default Re: del sol a/c question
no help. also does anyone have a bracket for sale
Old Jun 18, 2009 | 05:45 PM
gsrauto98's Avatar
gotta use a b-series bracket and compressor
Old Jun 18, 2009 | 06:03 PM
bmd116's Avatar
thanks! so im guessing its any b-series right?
Old Jun 18, 2009 | 06:15 PM
07jdmfit's Avatar
no you can run the d series ac compressor but you have to get a bracket from a del sol b16 or a crv , found mine on ebay shipped for $62.00
Old Jun 18, 2009 | 07:50 PM
R666_EK's Avatar
Yeah. If you are running a D series now you can use the stock A/C compressor and you will need to pick up a del sol (dohc) bracket, or CRV b20. (cheaper)
Old Jun 18, 2009 | 08:09 PM
bmd116's Avatar
Old Jun 18, 2009 | 08:50 PM
eg grom's Avatar
I had heard that the b series swaps in smaller rides like the del sol an eg actually leave very little room to even fit the compressor. Is this true?
Old Jun 24, 2009 | 12:41 PM
bmd116's Avatar
new question up
Old Jun 24, 2009 | 01:42 PM
B18CivicEJ8's Avatar
Originally Posted by bmd116
also wanted to add that i wanted to use a b-series compressor
thanks for all the help guys i appreciate it
But why? You'll get no advantage of using a b-series compressor. Besides, you'll have to find new A/C lines to match the b-series compressor, evacuate your entire a/c system, and then refill. Your car was totally designed to have a b-series motor with a d-series compressor stock. That's what the del sol VTEC bracket is for. Why go against nature? In addition, the del sol vtec bracket won't fit a b-series compressor.
Old Jun 24, 2009 | 02:27 PM
fastrxu's Avatar
If you opt for a b series compressor you need to have custom fab fittings on your current lines. Teg or si lines wont fit.
The d series compressor is bolt on. I got the p7j crv bracket for like $40 from hondapartsnow.com
Just remember to get the idler mechanism as they're different from the d series bracket
Old Jun 24, 2009 | 03:22 PM
bmd116's Avatar
lol i forgot i put that i was goin with the d series compressor but like i was askin b4 can i use the p7j without the torque mount?
only reason i ask is because this guy i kno is sellin one but shaved off the torque mount(idk why)!
Old Jun 24, 2009 | 03:57 PM
Personally, I would not run without torque mounts. The torque mounts prevent the engine from torquing back and forth and also prevent the engine from entering the passenger compartment in the event of an accident. There are countless threads of others on this very site asking for help after their engines fell out because they heard it was ok to run without torque mounts.
Old Jun 24, 2009 | 09:04 PM
fastrxu's Avatar
maybe if you have super stiff mounts you need not worry about torque mounts
but I have innovative red mounts and I run with torque mounts; I figure it can't hurt me
as for using the p7j without torque mount of course you can. Just take your torque mount off. You don't need to shave nothing off. the bracket if the mount is not there the rod that goes into the torque mount will just be there. It wont make contact with anything don't shave it off
Kendawg386
Aug 24, 2012 11:23 AM
PhatHardy
11
Jun 23, 2005 01:05 AM
rkn527
Aug 26, 2004 06:24 AM
civcexcoupeblack
Jul 14, 2003 10:07 AM
