BRAKE PROBLEM!!!! 93 CIVIC EX
Old Jun 18, 2009 | 11:02 AM
SIC_WIT_IT's Avatar
Icon2 BRAKE PROBLEM!!!! 93 CIVIC EX
ok here is the deal. i put a new caliper and hose on the front right of my car..bled the brakes and when i drive around tow i can feel the passenger side claiper slowly squeezin my rotor and eventually it gets to the point to where i cant move my car..someone tell me what the fuc is going on..please!!!!
Old Jun 18, 2009 | 11:07 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: BRAKE PROBLEM!!!! 93 CIVIC EX
ur brakes are locked up son
Old Jun 19, 2009 | 07:39 PM
SIC_WIT_IT's Avatar
well duh **** captian obvious..im trying to figure out what the cause besides he master cylinder brake line or caliper...which are all new..and why is it just on the passenger front
Old Jun 19, 2009 | 08:04 PM
pemd5555's Avatar
check the lines and caliper. If you take it off and it retracts easily then check the rubber brake hose and metal lines.
Old Jun 19, 2009 | 09:18 PM
waaBAAH's Avatar
whcih way is the car pulling?
if it pulls right while braking..then it is your LEFT caliper. it is always opposite of teh pull.
vehcile will always pull with the most "braking force". so lets assume your LEFT caliper is frozen at 50 psi and your right is at 0 psi... if you apply the brake you get 100 psi. 0 to 100 is more braking power then 50 to 100. so in this simply case you would be looking at a right pull while braking
eggsxr
Apr 19, 2013 08:37 AM
NOTUNINGNONADA
Jul 21, 2010 09:03 AM
flowgetta
Apr 16, 2009 12:09 PM
gophat
Jan 7, 2007 05:32 PM
lv6l
Jan 19, 2006 06:24 AM
