First build, engine selection. Where do I reasearch Honda engine models?
Ive decided its time to finally do a restoration project. I want to (as of right now) rebuild a 88-91 Civic or CRX. That being said I would like to start doing research on the different Honda engine models available. I basically want to build the engine as much as possible and keep it NA. Where would everyone recommend I begin doing research. Im not a nube but no expert. I just really want to educate myself about it and then build a solid engine to drop into a fully restored car. Thanks in advance!
Get a b16. They are pretty cheap. I would start there then maybe a ls block later on down the line If you need more power
Intended budget and application would help people know which direction to point you. I agree, a B16 would be a good way to go. There's an abundance of parts and ways to make power, and is probably the most straightforward swap into the chassis without a lot of work. If you're looking to get crazy, do an f20c swap and turn it RWD
