b16a in eg sedan. no fire easy fix?
Old Jun 18, 2009 | 12:32 AM
TeggieeTuner's Avatar
Default b16a in eg sedan. no fire easy fix?
at first i had a b18b1 obd2 engine and engine harness and distributer with obd1 everything else.
ran fine.
swapped a b16 in with everything the same still and now im getting no spark.
could it be cause of the knock sensor not being hooked up?
i pulled the distributer cap off and tested for power on the coil with the ignition on and i only have power when i put the negative end of the multi-meter to a bolt or good ground on the engine.not when both ends of the multi-meter are on the coil....
so my problem is a ground somewhere.....
Old Jun 18, 2009 | 08:44 AM
xjosfx's Avatar
I LIVE IN
Default Re: b16a in eg sedan. no fire easy fix?
coil?
Old Jun 18, 2009 | 08:57 AM
kp's Avatar
kp
ran fine.
I think you might be confused as to how a multimeter works. Do you know anyone that is experienced with electrical work?
Old Jun 18, 2009 | 09:08 AM
Former User's Avatar
Sounds like the distributor gets battery power. Remove the coil and ICM so that an auto parts store can test them.
Does the fuel pump prime? If not, check the critical ground wire attached to the thermostat housing. It may be disconnected, loose, or corroded.
Is the CEL ON?
Modz+Civic= <3
13
Jun 1, 2012 05:42 PM
spraymysol
Oct 21, 2008 05:40 PM
x19trix72x
Sep 30, 2008 04:43 PM
ChilBlu92
Dec 28, 2006 06:35 PM
SLVRSTN_DC4
May 31, 2005 11:36 PM
