dsm injectors
Do you have any sort of electronically tunable fuel management system chipped ECU or standalone EMS such as AEM? Also do you have an injector resistor box?
If you just drop in a set of 450cc, low impedance, DSM injectors into a stock high impedance system it won't work for very long. If at all, I've never tried it personally.
Theoretically,
1. You'll be running way to rich without electronic fuel injection tuning.
2. The high impedance system, 11-13ohms, of a non resistor setup will eventually burn out the low impedance injectors.
Theoretically,
The high impedance system, 11-13ohms, of a non resistor setup will eventually burn out the low impedance injectors.[/QUOTE]
The injectors will not burn out, it's the injector drivers or transistors in the ECU that will suffer because of the decreased resistance meaning increased amp flow. A resistor box must be used with these injectors.
However, I was easily able to find the exact article that I read.
Originally Posted by Hondata.com Tech - Low and high impedance injectors
Conclusions
• Running low impedance injectors without a resistor box will substantially increase the temperature of the transistor driver IC due to the increase in current flow.
• The temperature increase will depend on your driving.
• If that temperature remains high enough for long enough the driver transistor will be damaged.
Tech - Low & high impedance injectors
Sorry, my bad. I miss quoted an article that I read 2 years ago.
If you want to read the complete tech article here it is.
