TPS is NOT getting voltage.. 0 at multimeter, 0% on datalogs
Old Jun 17, 2009 | 10:35 AM
marcj's Avatar
Default TPS is NOT getting voltage.. 0 at multimeter, 0% on datalogs
I am really confused at this point.. I just finished installing my 780cc injectors and the car was running like ****. So I look at datalogs, idle is at 19.9 AFR, this is a tune JD did for someone else on a similar setup, so I decided to make my own basemap in crome gold.. still no good. then I notice the TPS says 0% when i rev it up in the logs.. check the voltage and I get 0 volts at any position.
So, I've checked the actual wire all the way to the ecu, and it's good. I tested it by grounding a 9volt battery on one end meeting the sensor and checked it at D11 on the ecu side.. it's all good.
Not sure what to do at this point.. I tried another ECU and TPS .. what now???
Old Jun 17, 2009 | 10:37 AM
Former User's Avatar
Default Re: TPS is NOT getting voltage.. 0 at multimeter, 0% on datalogs
What year? If you are saying that the ECU does not supply 5 reference volts to the TPS, then the ECU is likely bad. Have you checked the VCC2 wire?
Old Jun 17, 2009 | 10:54 AM
marcj's Avatar
I just tested voltage between the green/black and yellow/blue and i only got .25v
where is the VC2 wire? I don't have the workshop manual right now
how exactly can i test for 5v from the ecu? I tested D11 and got nothing
Old Jun 17, 2009 | 10:57 AM
Sounds like the wire that sends the reference voltage (5V) from the ECU to the TPS is bad. What year?
Old Jun 17, 2009 | 11:07 AM
marcj's Avatar
1996.. what should i do now? shouldn't I get a steady 5 volt between those outside wires?
marcj's Avatar
I've tried 2 ecus.. both worked fine before this
Old Jun 17, 2009 | 11:16 AM
Unplug the TPS connector. Turn the key to ON(II). You should measure 5V from the TPS connector terminal for the YEL/BLU wire to body ground. If not, check the YEL/BLU wire for continuity or a short between the TPS connector and pin D10 of ECU connector D.
Old Jun 17, 2009 | 11:18 AM
marcj's Avatar
you are awesome!
crazyhorse2011
Mar 28, 2021 11:17 AM
Harrymonk
Jun 21, 2018 11:25 AM
supercharged d
Feb 17, 2010 07:07 PM
ferio 95
Dec 10, 2004 09:16 AM
