just a few questions(cluster, headlights)
Old Jun 17, 2009 | 10:04 AM
Choy's Avatar
Default just a few questions(cluster, headlights)
alight so i found out that i need a new cluster for my 99 si. a machanic replaced the speed censor in the car, but since then my rpm gauge sometimes sticks, and my temperature gauge doesnt work at all. how hard is it to replace the cluster? and when i do should i fix those two problems?
also my headlights are hid's and the mechanic said i have a bad converter, where can i buy just that. or how can i check to tell if its bad?
Old Jun 17, 2009 | 10:09 AM
Former User's Avatar
Default Re: just a few questions(cluster, headlights)
Before you replace the cluster, make sure the connectors at the rear of the cluster are tightly seated and the connector terminals are not damaged.
Old Jun 17, 2009 | 10:13 AM
Choy's Avatar
**** its that easy?
Old Jun 17, 2009 | 10:15 AM
Also check the 1-wire coolant temperature sending unit under the distributor.
Old Jun 17, 2009 | 10:39 AM
Choy's Avatar
what? lets just pretend i know nothing about cars =]
Old Jun 17, 2009 | 10:46 AM
The dash temperature gauge gets the temperature signal from a sending unit located below the distributor. This sending unit is connected to a single wire. One possible reason that the dash temp gauge does not work could be that the sending unit is bad or its connector is loose or damaged.
Old Jun 17, 2009 | 07:58 PM
Choy's Avatar
oh ok gotcha. wheres the distributor?
Old Jun 17, 2009 | 08:07 PM
...wheres the distributor?
Old Jun 17, 2009 | 08:28 PM
hOnda_hiEn's Avatar
doesnt get any easier than that..
Old Jun 17, 2009 | 08:42 PM
knivesout's Avatar
When you say the "converter" for your HIDs, I believe what you're talking about is the ballast. Is one of your headlights not working? Ballasts are usually sold in pairs but I'm sure you could find a spare one somewhere. Prices vary.
Old Jun 18, 2009 | 03:03 PM
Choy's Avatar
idk its some kind of little boxes on both lights.
Old Jun 18, 2009 | 03:05 PM
Choy's Avatar
in this picture it shows 6 different wires, i took off the cluster and i only have 5 and only 4 are connected. the 5th is an orange color and there isnt a place for it
Old Jun 19, 2009 | 07:43 AM
Choy's Avatar
bump
Old Jun 19, 2009 | 07:48 AM
Old Jun 19, 2009 | 12:37 PM
Choy's Avatar
connections A and D arent hooked up there are no places for them to go
Corton93
Oct 31, 2018 08:26 AM
byrne_06
Oct 24, 2010 03:31 PM
sirjmj
Jul 6, 2008 10:27 PM
vtec.dc2
May 22, 2006 12:36 PM
