Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2000 Odssey running lights
Old Jun 17, 2009 | 06:50 AM
elelectric's Avatar
Default 2000 Odssey running lights
Should never bragged how little has been wrong!
Basically have no daytime running lights. When you turn on headlights have no high beams and only low beams. Bulbs are good. If you start van with lights off in low beam positon a relay(I think) in upper left behind dash squeals. Click the dimmer switch to high beam and it stops but no daytime running lights.
Now here is where it gets weird. If you hold the flash high beam switch on as you turn on the headlights you get one high beam to come on but it is not always the same light, and then when you switch to low beams they come on but it seems like it is actually daytime running lights( dimmer than normal I think) but high beams won't come back on until the van has been shut off for a while.
..One other thing if you are on arough road and shake the van a bit the daytime running light indicator light while flash with every bump.
Is it a ground problem ? I'm stuck on this one
Thanks for any ideas!!!
Jefferin000
Apr 28, 2014 07:17 AM
illusion
Aug 9, 2013 07:00 PM
teamWARej1
Nov 22, 2012 07:07 PM
JoseCuervo
Lighting
Feb 28, 2012 04:38 PM
stupidwhitecat
Nov 5, 2005 04:26 AM
