Camshafts won't stay aligned?
Old Jun 15, 2009 | 12:02 PM
JJexpress's Avatar
Default Camshafts won't stay aligned?
Hi,
I have an h22a and when I align the camshafts to TDC and then rotate them with the timing belt, they fall out of alignment.
I noticed that my exhuast camshaft rotates much more easier than my intake camshaft which is harder to turn.
Any ideas?
Old Jun 15, 2009 | 12:29 PM
117's Avatar
117
Default Re: Camshafts won't stay aligned?
Are you trying to install the timing belt? If so, that's normal. You need to use a couple of wrenches on the cam gear bolts to rotate the cams into the proper position. Once the belt is on, hold the timing belt in place on the cam gears as you turn the engine over by hand. Once you get more than a 1/2 rotation of the crank, you should be able to move your hand. If you don't hold the belt in place it WILL slip when you initially turn it due to the slack in the belt. Obviously, you remove the autotensioner stopper once the belt is on and before you turn the crank pulley.
Old Jun 15, 2009 | 12:39 PM
JJexpress's Avatar
I did a manual tensioner conversion - will this method still work?
Old Jun 15, 2009 | 12:42 PM
117's Avatar
117
Yes, but you need to tension the belt properly (per the manual).
ef846
Feb 12, 2009 09:41 AM
kornerk12
Nov 25, 2007 02:03 PM
-Gambit-
Nov 13, 2005 04:13 PM
weraider30
Jul 24, 2004 10:36 AM
AdamITR
Aug 28, 2002 07:11 PM
