sensor question !!!
Old Jun 14, 2009 | 04:16 PM
xci9v8icx's Avatar
Default sensor question !!!
had just installed a new header and the lower o2 sensor port was farther down so i had to fab the sensor to fit ie making it longer and soldering it together but i just ran into a huge problem lol it does not fit in the port!!!!!! wtf can i do with it?????
and help would be apprecieated also do you happen to know if i could buy like a 3 ft sensor or is that out of the question?????
and if i ran my car with only the top sensor would that create problems???????
Old Jun 14, 2009 | 04:52 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: sensor question !!!
it wouldnt be that bad. you could put a bolt in the o2 bung. and take it to a shop and hav them weld a new bung..that fits your o2 sensor. cut the wires on the o2 sensor will make it prolly not work as good. they have some weird electro shell stuff in the wires.
Old Jun 14, 2009 | 05:24 PM
xci9v8icx's Avatar
thing is i HAD to cut the wires for the o2 sensor to fit cause when i install the header the sensor plug was farther down under the engine as opposed to right by the front of the engine with the stock header!
Old Jun 15, 2009 | 05:58 AM
I'm not Rick!
get a good gauge wire and solder it and plug it in and see what happens
Old Jun 15, 2009 | 01:24 PM
xci9v8icx's Avatar
i wish i could plug it in but the sensor does not fit into the lower part of the header........ so back to my question will it cause problems if i run it without the lower sensor i was told that is only to tell me if im emmiting bad fuels but does it regulate anything or is that only the top sensor??
Old Jun 16, 2009 | 09:29 AM
I'm not Rick!
i wouldnt worry about it. alot of people go with it.
Markadler47@gma
Mar 22, 2019 02:36 PM
Nataku
Jul 3, 2008 09:44 PM
01blackgsr
Jun 24, 2006 06:23 PM
tuan...
Mar 17, 2004 10:05 PM
SIckH22Atch
May 8, 2003 09:49 AM
