Need info on compatibility
Old Jun 14, 2009 | 01:42 AM
Rob97'SH's Avatar
Default Need info on compatibility
Looking to get a taller final gear for my 5th gen base trans (top speed) Does anyone know if M2X4 (AuDM) or M2V5 (EuDM) internals ,mainly final gear. go into a M2Y4 (US base trans)
Tire Size: 215 40 17
Redline RPM: Final Drive Ratio: 4.062
1st Gear:3.285 Ratio:45 Max MPH: Shift Point:
2nd Gear:1.956 Ratio:75 Max MPH: 5054 Shift Point:
3rd Gear:1.344 Ratio:109 Max MPH: 5788 Shift Point:
4th Gear:1.034 Ratio:141 Max MPH: 6471 Shift Point:
5th Gear:0.812 Ratio:180 Max MPH: 6574 Shift Point:
6th Gear: Ratio: Max MPH: Shift Point:
This calculator is from Mfactory website. Don't ask me about shift points thats what it said but wouldn't it be nice to go 180 on a boosted motor? Not that you could do that around the states but just to know you can. And with the Final dropped from 4.266 to 4.062 you shoudnt loose too much of the low end.
Predefined Gear Ratios:
Old Jun 15, 2009 | 08:31 PM
92civlude's Avatar
Default Re: Need info on compatibility
I have swapped the ring gear and countershaft for a customer. From a M2F4 4.26 into a P2A5. to replace his 4.06 gear ratio. Kinda like the opposite of what your'e doing. It bolted in nice! I also swapped out my short geared trans for an Accord trans on Saturday. MY CAR IS SICK FAST NOW!
Rob97'SH
Transmission & Drivetrain
Jun 16, 2009 09:01 AM
westazcivic
May 11, 2008 07:52 PM
TypeR0149
Oct 20, 2003 10:22 PM
B2FiNiTY
Nov 30, 2001 11:02 AM
