Integra rear hatch latch problem!
Old Jun 13, 2009 | 06:01 PM
hondacbx's Avatar
Default Integra rear hatch latch problem!
Sometimes my latch works and sometimes it does not??? I think this is a comon problem but I couldn't find a post. Do I need a new part?
Old Jun 13, 2009 | 11:35 PM
R-box's Avatar
Default Re: Integra rear hatch latch problem!
So all your other door locks work?
Old Jun 13, 2009 | 11:51 PM
emaka9's Avatar
i have same problem :? except mine doesnt open at all :/ here
https://honda-tech.com/forums/acura-integra-type-r-8/trunk-release-problem-solution-dont-give-accura-cent-1427911/
Old Jun 14, 2009 | 02:05 AM
ITR525's Avatar
my latch gets stuck open somtimes!
Old Jun 14, 2009 | 02:26 AM
emaka9's Avatar
mine used to get stuck open too. but only if u pull the lever too hard. it locks it open for some reason :/
Old Jun 14, 2009 | 04:04 AM
98ITR747's Avatar
You need to hit it with some oil. WD40 will do the trick temporarily to prove if that is the problem or not. Long term you'll need an oil that is less likely to evaporate as quickly as WD40 can.
Old Jun 14, 2009 | 07:07 AM
Tweakmeister's Avatar
You can still open it with your key.
This is a common problem with Integras.
Old Jun 14, 2009 | 08:13 AM
RyCeRoCkeTz's Avatar
Glad I'm not the only one with the problem. I notice I had to shut it a tad harder than usual for it to even lock!
Old Jun 14, 2009 | 11:53 AM
hondacbx's Avatar
Mine locks ok, it just wont unlock and it does not work with the key!
Old Jun 14, 2009 | 02:12 PM
R Legend's Avatar
There are a few minor parts that can be purchased and installed DIY style. Fairly easy fix, for a very common and annoying problem. Dealership wants 450+ for parts and labor.
Old Jun 14, 2009 | 03:45 PM
b18c5 power's Avatar
i want to know if it`s possible to change the key cylinder of the hacth only, so it match my door key cylinder or do i have to change everything???????
Old Jun 14, 2009 | 04:15 PM
Shalom's Avatar
Grease?
Old Jun 16, 2009 | 10:35 AM
tipe R's Avatar
i have had a few issues with mine. The actuator motor itself doesn't work so the hatch wont pop when you hit the switch. Also there is a switch on the trunk lock cylinder to lock and unlock all the doors which is held on by 2 screws- the screws on mine came loose and just had to be tightened for it to work. If you need a key cylinder, you should be able to buy a new or used one and have it coded to your key at any lock smith but you should check all linkages first
Old Jun 16, 2009 | 11:52 AM
PaulMc's Avatar
Painfully Stupid
Kindof funny how I just got done struggling with this in my garage, come to the computer and see this thread. It does get stuck over to the right and doesn't want to lock! I used to just spit in the latch and it worked for a few months when I had my LS LOL.
Old Jun 16, 2009 | 11:59 AM
Nu2DaGame's Avatar
Its the actuator. my car locks and unlocks fine, but sometime i couldnt get it to pop open. after i swap out the actuator its all good. easy fix and it cost if i could remember right 60-80 bucks at the dealership
Old Jun 16, 2009 | 12:34 PM
IanBlake's Avatar
same problem here
Old Jun 16, 2009 | 12:36 PM
IanBlake's Avatar
here is how to fix your problem
http://www.team-integra.net/sections...ArticleID=1259
Old Jun 30, 2009 | 01:46 PM
tipe R's Avatar
on mine the actuator doesnt make any noise but does have power and ground, I guess I could replace the electric motor inside but the complete assemble isnt too expensive
lawnrider
May 11, 2012 10:32 PM
Projectjdm4
16
Apr 27, 2008 02:53 PM
vtec8804
Feb 7, 2007 04:37 AM
NUTWEAVE
Dec 29, 2003 03:10 PM
SamuraiJack
May 30, 2003 07:58 AM
