Aftermarket wheel, srs light? inspection?
Old Jun 13, 2009 | 05:33 AM
01_ITR's Avatar
Default Aftermarket wheel, srs light? inspection?
i have a brand new spoon wheel that i wanted to put in my ITR, but before i did i wanted to make sure that there was a way i could still pass inspection when the time comes. Once i take out my stock wheel and put the spoon wheel in, the srs light will be on. If i keep my pass. airbag system in can i just install my stock ITR wheel and reset the srs light and pass inspection, or am i oversimplifying the process? I know a lot of people put aftemarket wheels in 96+ cars. Any advice will help...
Old Jun 13, 2009 | 08:28 AM
Ill's Avatar
Ill
Default Re: Aftermarket wheel, srs light? inspection?
Someone else will post further details, I'm sure. But I see no reason why what you propose won't work. The only problem is that you cannot sell your stock ITR wheel. Then again, it is best not to sell one's stock parts when modding - for possible later resale.
Old Jun 13, 2009 | 09:01 AM
Spids5's Avatar
Don't judge or question
You don't need to put your stock wheel back in to turn the SRS light off. If you want to run the Spoon steering wheel without the SRS light on you will need to get a 2.2 ohm resistor to simulate the airbag. Then you will need to reset the light using the instructions below.
Old Jun 13, 2009 | 09:20 AM
Ill's Avatar
Ill
<pics>
Oh yeah. H-T often sucks, but it more often RULES!
FYI - 'SCS Service Connector' = Paper clip
Old Jun 13, 2009 | 02:43 PM
jzak1's Avatar
What state is your emissions testing? As long as your check engine light isn't on, srs may be overlooked because it's not emissions based, but on the safety aspect, it should pass. Remember, if your oem steering wheel came with horn buttons, your aftermarket wheel should have a visble horn pad on the wheel as well-state inspectors look for that. good luck
Old Jun 13, 2009 | 04:46 PM
Pr-Type-R's Avatar
this man is always right! ive dont it..it works 100% if you have any questions on it pm me. i did it on a OEM JDM Non srs wheel..and the horn is fairly erasy to get working also
Old Jun 14, 2009 | 05:47 PM
01_ITR's Avatar
thanks for the help, im located in CT and emissions does not look for this kind of stuff, only exhaust and evap issues, so it looks like i can pull the airbag system on both sides if i wanted. Someone may want to clear this up but someone told me if i dont have the airbag system on the driver side the pass. side airbag wont work so i should remove it anyways...
Old Jun 14, 2009 | 05:50 PM
Spids5's Avatar
No the passenger side airbag will still work if you do what I posted above. With the 2.2 ohm resistor the system will not know that any airbags were removed.
Old Jun 15, 2009 | 12:15 PM
01_ITR's Avatar
thankss. Is there a way to simulate both airbags, i was planning on taking both airbag systems out without have my srs light on
Old Jun 15, 2009 | 04:50 PM
cmdr430's Avatar
is this car street driven/daily driver ?
If so, leave the air bags in and useable, your life will thank you.....
Old Jun 15, 2009 | 04:57 PM
Spids5's Avatar
Yes, do the resistor trick where both air bags use to be.
Old Jun 15, 2009 | 10:46 PM
Status R's Avatar
keeping heR these days?
Old Jun 16, 2009 | 08:49 AM
Shalom's Avatar
If you're removing the airbags, why not just remove the SRS light from the gauge cluster, problem solved. Going through and putting in a resistor to "simulate" the airbags seems kind of pointless, when they're not even there.
Old Jun 16, 2009 | 12:03 PM
PaulMc's Avatar
Painfully Stupid
If you just pull the bulb out from behind the cluster will they know at Inspection when they hook it up to there computer anyway?
Old Jun 16, 2009 | 12:33 PM
Pr-Type-R's Avatar
x2..if your gunna take out airbags...i did the resistor trick because i wouldnt risk a passengers life...unless your gunna Track the car then i guess it doesnt really matter? but heres a video of how mines works with no airbag and the SRS light going off
after startup..aka working normally
View My Video
Old Jun 16, 2009 | 01:28 PM
sti grip's Avatar
plug in a .03 om resister and that should work we do it is subarus for the seats and the steering wheels
Old Jun 16, 2009 | 01:29 PM
Shalom's Avatar
What are they plugging in at your "inspection"? The only thing any state inspection has ever plugged in would be an OBD-2 port scanner, and that doesn't read SRS codes, its emissions related.
Old Jun 18, 2009 | 11:34 AM
a97b18b's Avatar
Where do you put the resistor? This is how I did my ITR non SRS steering wheel. http://www.team-integra.net/sections...ArticleID=1226
Old Jun 18, 2009 | 11:41 AM
sackdz's Avatar
01-ITR
If you are removing the passenger airbag too, then you may as well remove the control module and wiring harness as well... and the cluster lamp too if you wish but it ain't going to lite without the module.
Old Jun 18, 2009 | 01:01 PM
eluam's Avatar
In Virginia, the SRS light must come on during start up, and then turn off. If it doesn't turn on at all, or doesn't turn off when it comes on, it doesn't pass inspection.
Now if you remove the ENTIRE SRS system, it will pass inspection, but you cannot just remove one component. All or nothing. I'm sure other states are the same.
Old Jun 18, 2009 | 03:29 PM
sackdz's Avatar
Then you just jump the SRS lamp to the CEL lolz
CrackThatTec45
Sep 4, 2009 07:51 AM
steam
Sep 5, 2007 08:17 PM
erck
Jun 8, 2007 07:34 PM
Marauder
Apr 11, 2003 03:26 PM
servion
Jan 14, 2002 01:54 PM
