'96 spec and '98spec
Hey guys, I'm somewhat new to the car world and I'm interested in getting a '96 spec (really a '95) JDM Type R and have a few questions
Are the '98s considerably better performers (handling especially) than the '96s? Also, is it possible to convert the '98specs 5 lug?
Were the Red Recaro seats optional for the '96 spec?
I wouldn't consider the '96 Spec to be a "better performer", the major differences between the '96 Spec ITR and the '98 Spec ITR is the 5-lug suspension, brakes, HID headlights, SRS wheel was available. The Recaro seats were available in all the years of the DC2 production.
Below is a clip from "Type-R legend" comparing both the '96 and '98 Spec ITR.
http://www.youtube.com/watch?v=34H2MCPEUV8
They were also available in yellow too. :p
except you forgot the link. it's easily found on youtube though. i remember the 98's larger brakes and abs really helped the braking in addition to what others have mentioned. the 98s also came with HID lights
In that movie they raced a civic type r, '96 spec type r, and '98 spec type r. Civic came 1st, '96 spec, then '98 spec... and in the straight away the '96 and '98 had the same times. '98 had better breaking though...
Gotta finish watching the movie
The 98 spec is just a slight upgraded version.
Main differences in appearence are HID headlights, 16 inch rims, rear bumper
Main differences in performance are 4-1 header, 4.7 final gear with longer 4-5 gears, bigger brakes
will a 96 spec motor perform better with a 4-1 header?
does anyone know if the '98 spec HID headlights are compatible with a '96 spec with ABS since I heard the older abs' were bigger..
-FFFFFFFFUUUUUUUU, isn't compatible and im guessing you can't go from '96 spec to '98 spec ABS?
All ITR's have the newer style ABS system so this would not be an issue
