window wont role down
Check the motor. obviously take the panel off and then see if connection is loose or if motor is blown. Actually before any of that check the fuse box, I am not sure which fuse, but they are there.
Check your Vtec! If not engaging, the window won't work! No Vtec, window won't role down.
For non-automatic window!
Check yourself! Make sure you are rolling down the window!
For automatic window!
Loose wire connection, if not 99 percent is the motor. It won't be the fuse, if the other window works! Use a 12v power connection and power up the window motor it self! check that!
