2000 civic si low idle problem
Old Jun 11, 2009 | 12:16 PM
Em1_coupe's Avatar
Default 2000 civic si low idle problem
Ok so a couple of weeks ago i was driving and wen i was stopped at a light my car started idling real low like it was going to die but the idle would always go back to normal 1k, then today it was doin the same thing except this time my car would die any help will be use full thanx for viewing
Old Jun 11, 2009 | 12:26 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: 2000 civic si low idle problem
clean your iacv. check compression and your dizzy cap
Old Jun 11, 2009 | 12:32 PM
Em1_coupe's Avatar
thanx for the help i cleaned out my iacv a few months ago i will get my compression checked n how do i check if my dizzy cap is bad?
Old Jun 11, 2009 | 12:39 PM
I'm not Rick!
take it off and look at the electrodes in the inside and look for corosion. i had teh same problem almost. i barely had corrosion. new cap . idled fine. but wierd idle can be lots of thigns. do the little checks everywhere first before buying parts
Old Jun 11, 2009 | 03:20 PM
Former User's Avatar
Is the CEL ON?
Old Jun 11, 2009 | 05:38 PM
Laz's EP's Avatar
I have the same problem, it idles low until it warms up,then it idles normal Is this what happens to you??
Old Jun 11, 2009 | 06:36 PM
goldfinger93030's Avatar
Mine is a little weird it drops and then goes back up but that happens after its warm when its cold it idles fine
Old Jun 11, 2009 | 07:10 PM
xci9v8icx's Avatar
same problem and i have a cel on for evap system error code
Old Jun 11, 2009 | 07:27 PM
Meyerman015's Avatar
well, this is what i did...
changed spark plugs and did an oil change... the idle was much better, but would drop and then quickly go back up... then i filled my tank up with shell gas after using bp for about a month and it went back to normal...
Old Jun 11, 2009 | 07:32 PM
xci9v8icx's Avatar
yes when i first bought my car the guy was running regular non syntec oil and regular gas i switched over and this problem started happening very minimal too me i have never had it stall but it seems like the same problem
it happened last week for about a minute
i also notice when i make perfect shifts a few times it goes normal
but did you notice its really harder shifting cause the rpms drop rapidly??????
Old Apr 7, 2015 | 05:01 AM
that.em1's Avatar
I seem to be having this exact problem. i will be checking all of the possible solutions to this problem. This just started yesterday night and I wonder if it might need a tune up? While its cold the car runs beautiful, after it warms up its a violent jerk while in gear and wants to die. i will look further into this and be checking all the possible solutions posted on this page! Thank you internet for the invention of a forum to gather intelligence before I go straight to a swap.
Old Apr 7, 2015 | 03:12 PM
Jimi Hondrix's Avatar
Seafoam it... Seafoam cures all problems.. just ask the manufacturer..lol
Old Apr 7, 2015 | 06:27 PM
92egghatch's Avatar
Vac leak?
Old Apr 8, 2015 | 04:35 AM
purgat0ry's Avatar
Are you functionally retarded?
Secondly, stop rezzing old threads.
Old Apr 8, 2015 | 10:09 AM
Does your mom have a *****? Of course I was joking about Seafoam.
Egchico69
11
Nov 30, 2012 01:30 PM
kamakaze1
Nov 3, 2005 06:02 PM
Boofster
May 22, 2005 10:59 AM
Losled
Feb 7, 2003 06:18 AM
