Stalling problem
Old Apr 15, 2005 | 05:01 PM
Boofster's Avatar
Default Stalling problem
Finally got the car back in one piece but now more issues....
When the car gets warm and I get off the gas, like come to a stop light, the rpms go to idle and then 1 sec later just drop and shut off. Then on restart, it's ok until I drive to the next light....
Any ideas what else to check?
- Did compression test - even across the board at 200.
- Vacuum is good
- No coolant bubbles
- Oil ok
- No air out of the breather
- Idle timing at 16 flat
- Good plugs
I'm tempted to put back the stock ignition and see what happens.
The car is also Neptuned so I doubt it's the tune.
EDIT: Just tried taking off the IACV with the car on and it started bouncing. A lot of air was going through the opening though. Is that normal? I thought idle was just supposed to go up. The idle screw on the TB didn't change anything when I messed with it.
Old May 22, 2005 | 10:59 AM
Boofster's Avatar
Default Re: Stalling problem (Boofster)
IACV was replaced. Much better with the new one but still had the problem. Unplugging the Evap Purge solved all the issues though.
DO/\/\O
14
May 9, 2011 05:56 PM
92egSnatch
Mar 22, 2008 08:55 PM
jdmgeezer
Dec 9, 2007 11:23 PM
speed junk1e
May 29, 2004 10:49 PM
