Taillights do not turn on when I turn headlights on... but all other lights work!
Hey, i recently purchased an 05 Rsx type s that currently has a problem which led to a fix-it ticket. My court date is 6/30/09 so it needs to be addressed ASAP. The problem occurs when i turn my headlights on, the tail lights do not turn on!
Cliffs:
Brake lights work
Signal lights work
Turn signals work
Outside lights work (when I unlock car)
Which lights are supposed to turn on when the headlights are flipped on??
Also, PART of the climate control does not light up, but some of it does.
I've checked all the fuses and none are out that I can find.
is there a specific fuse i should replace?
-Evan
Cliffs:
Brake lights work
Signal lights work
Turn signals work
-Evan
its your 'parking' lights fuse that you want to check, and they are usually only 10amps. that would be my first guess
pliskin8
Jul 7, 2011 06:30 PM
1JDMDOMINICAN
Oct 28, 2005 06:34 AM
