help!!! 99 gsr front oem camber???
so, a friend of mine just purchased a set of skunk 2 front upper ajustable control arms and realized that after he took off the stock cambers to put them on the new arms he forgot what side went where. does it matter what side or where they all go on? they all look fairly the same in everyway but each of them has a number on them. two of them say 8/3 one 8/4 and the other one 8/1? if anyone could help a fellow enthusiast out with this mixup? one luv & thanx...
I just bought brand new OEM upper arms, still in the box, so I can check them this evening when I get home.
Also, there is no such thing as "cambers". Camber is a term describing the angle of the wheel hub from vertical.
I noticed mine all say 7/0 or 7/1. There is one of each on each of my new left and right UCA's.
7/1 is towards the front and 7/0 is towards the back on both arms. The numbers both face out from the UCA on the right arm, but on the left arm both numbers face the front of the car.
Most likely it doesn't matter which way they go.
sixteenfeet
Jul 8, 2014 03:43 PM
JDMCRX
Suspension & Brakes
10
Apr 11, 2013 04:57 AM
