GSR Turbo Exhaust Size?
Old Jun 10, 2009 | 04:12 PM
thanh4o8's Avatar
Default GSR Turbo Exhaust Size?
I need some opinions. I have a STOCK gsr that im about to boost. Hoping for mayb around 250whp Daily. What size piping should i get? 2.5" or 3" ?
Old Jun 10, 2009 | 05:13 PM
omgwtfbbq's Avatar
Default Re: GSR Turbo Exhaust Size?
i have 250hp and my stock ls/v turbo likes my 2.5 exhaust just fine. it all depends. I've heard that they've seen up to a 30hp difference with the two sizes, 2.5" being the lower....but that was on a built motor....you have a stock one.
Old Jun 10, 2009 | 05:36 PM
turbohatch96y7's Avatar
im going 3 inch all the way back cat less on my stock stock stock gsr
tell me how your biuld goes what size turbo u got
Old Jun 10, 2009 | 05:43 PM
thanh4o8's Avatar
Its a 57 Trim turbo. with a log manifold and 2.5" downpipe.
Old Jun 10, 2009 | 08:25 PM
HiProfile's Avatar
If your goal is 250whp with a 57trim, you could even go with a stock exhaust. The larger exhausts will just increase the spool time - and you'll need all you can get with that oversized turbo.
There is a huge difference when I open my 3" cutout, which otherwise runs through a stock Civic muffler. It actually cuts the amount of boost I can run in half due to the backpressure. 3" fits in most cases, so I'd suggest that route.
Old Jun 11, 2009 | 11:01 PM
itr909's Avatar
Yep I'd say go 3 inch. I just tunned my stock GSR with a T4 and I put down 315ph and 215tq at 11psi. You should make your goal with no problem. Becareful boosting is like a drug!
fastboy559
Oct 25, 2008 08:47 AM
stevecal
18
Sep 28, 2004 11:37 AM
Badger401
Jul 30, 2004 01:28 PM
JFG Kevin
Jun 9, 2004 06:24 PM
WRTEG
May 21, 2004 12:41 PM
