Compression Test
Old Jun 10, 2009 | 02:20 PM
civic_driver's Avatar
Default Compression Test
Hey guys,
I just did a compression test on my d16y7 and the numbers I got are 195, 187, 192, 197. Since they are above 135psi and are within 10% of each other I suppose the compression is good, right?
A note to those doing a compression test on 96-00 civics: All you have to do is remove the "fuel pump/(srs unit)" and "(ign coil)" fuses before doing a compression test. Both fuses are under the dash and both are 15amp.
I did 8 cranks/revolutions per cylinder as per the compression gauge manual's recommendation. Well, actually I did 10 but the manual recommends 8.
Old Jun 10, 2009 | 05:32 PM
Default Re: Compression Test
At first I thought the numbers were kind of high for a d16y7 with 70K miles on it. What do you think?
Old Jun 10, 2009 | 05:34 PM
mynameisChris's Avatar
Sounds about right to me.
Old Jun 10, 2009 | 05:35 PM
Targa250R's Avatar
be professional
It's fine.
Old Jun 10, 2009 | 05:44 PM
amtheiceman's Avatar
just right
Old Jun 10, 2009 | 06:22 PM
Wow, I remembered now, I forgot to hold the gas pedal at WOT while cranking the engine. Hmm. I'll redo it tomorrow and see if the numbers change.
Old Jun 11, 2009 | 03:01 AM
Targa250R's Avatar
be professional
It doesn't matter. It's fine. You're reading way too much into this.
Old Jun 11, 2009 | 08:08 AM
Yeah, I know. I just want to know what proper numbers I should be getting for this engine since I've never done a compression test before.
I'll redo it today just for kicks
Old Jun 11, 2009 | 10:47 AM
Jimster480's Avatar
the numbers do seem a litlte high. But that is perfectly fine. you have to worry when they are low lol.
Old Jun 11, 2009 | 01:17 PM
Ok, so I did the test again. This time I held the gas pedal at WOT and my numbers are almost the same. Here they are: 195-192-197-199.
The problem I see is that people say, the exact numbers don't matter, what matters is that they are within 10% of each other. Well, my question then is, if the numbers you get from different compression gauges are different then how do you know if it's time to change/rebuild the engine (i.e. when one or more of the cylinders drop below 135psi as is the case for 96-00 d-series engines)?
Old Jun 11, 2009 | 01:18 PM
Sr420Det's Avatar
Those numbers seem pretty sound to me. Why are you doing a compression test is it running like **** or something? Dont know seems one of those gauges is off
Old Jun 11, 2009 | 01:19 PM
Exactly, that's my question, how do you know when they're low enough to require engine replacement/rebuilding with any particular compression gauge.
Old Jun 11, 2009 | 01:21 PM
No, it's running great. I just did a valve adjustment and changed the spark plugs which were long overdue and it's running like new. I bought a compression gauge recently and wanted to see what the numbers are on a "healthy" engine so that I know when it's time to rebuild the engine (plus it's my first time doing a compression test, I just wanted to do it )
Old Jun 11, 2009 | 01:43 PM
Jimster480's Avatar
if its below like 120 on a stock motor there is a serious problem. But it varies per motor since different motors have different compression ratios. So they would have higher PSI from the beginning
Old Jun 11, 2009 | 02:09 PM
Targa250R's Avatar
be professional
When the engine is bad, you'll know it. Trust me.
A D16Y7 won't due of gradually lowering compression. If anything, it will die of head gasket failure or catastrophic oiling issues.
Old Jun 11, 2009 | 02:27 PM
Jimster480's Avatar
nah it can. My original Y8 was beat to ****. I never compression tested it but I know it was low. I got beat by stock DX's and ****, and I couldnt even hit 100 in it until i got a P2P and even then i could barely get to 105. But it didnt burn oil or spin a bearing, it was all stock it just sucked major dick lol.
Old Jun 11, 2009 | 03:05 PM
A headgasket failure would be much easier to fix. I hope it lasts at least until it hits 150K miles. Anything more is bonus.
Old Jun 11, 2009 | 04:41 PM
Jimster480's Avatar
mine had like 150k on it when i bought it.
Old Jun 11, 2009 | 07:10 PM
Targa250R's Avatar
be professional
Not with higher mileage. If you freshen the head on a worn bottom end, it's going to burn oil like nobody's business. Once the head gasket goes, you might as well tear it down completely to at least re-ring it and hone the cylinders.
Old Jun 11, 2009 | 11:06 PM
jluo_hatchy's Avatar
sounds fine to me. nthing to worry about
Old Jun 11, 2009 | 11:42 PM
likwid2u's Avatar
when i worked at c&t japanese engines if the motor was under 150 on compression the motor would smoke customers would come back and complain
Old Jun 12, 2009 | 06:32 AM
Jimster480's Avatar
wtf are you talking about? A worn bottom end? If you dont overheat your **** then it wont be warped and the bottom end wont be "worn" so you can replace the gasket and its all good. My friend just replaced the gaskets on a motor that had 200k, it doesnt burn oil for **** so dunno what your talkin about.
Old Jun 12, 2009 | 06:58 AM
Targa250R's Avatar
be professional
Okay . . .
Everything obviously went over your head.
That's fine. Once you get a little bit older than 18 and get some experience under your belt, you'll see what I mean.
Old Jun 12, 2009 | 07:55 AM
Jimster480's Avatar
Okay . . .
i already have plenty of experience, thanks.
76 camaro car
Apr 20, 2017 04:47 AM
92vxjdm
Aug 15, 2008 05:05 AM
snowblind7x
Apr 13, 2005 08:12 PM
MechEng
Feb 11, 2002 06:15 PM
