Problems with 99 Civic, D15z1 motor inside, what dizzy to use??
Old Jun 10, 2009 | 01:49 PM
1SikEagle's Avatar
Icon6 Problems with 99 Civic, D15z1 motor inside, what dizzy to use??
I currently have a 99 civic with a d15z1, im trying to use the d16y7 dizzy but its not working, any ideas? should i use the d15z1 dizzy and repin to obd1. or should the y7 dizzy work?
Old Jun 10, 2009 | 02:11 PM
CivicSpoon's Avatar
Default Re: Problems with 99 Civic, D15z1 motor inside, what dizzy to use??
Only the distributor from a Z1 or a D16Z6 will physically bolt right up to the head. You should be able to just swap the innards of the Y7 distributor into the Z1 distributor (if you have it). That way it bolts up and you have the correct plug.
Old Jun 11, 2009 | 02:09 PM
1SikEagle's Avatar
I need a obd2 dizzy, the y7 dizzy bolts up fine, but wont start the car, the plug i need is obd2 plug. what dizzy should i buy or put together?
Old Jun 12, 2009 | 09:14 AM
1SikEagle's Avatar
Bump
Old Jun 12, 2009 | 11:07 AM
CivicSpoon's Avatar
The Y7 distributor should not be bolting right up to the D15Z1 head; the bolt pattern should be different. Are you sure that it's bolting up to all 3 holes? If it is, are you sure it's a D15Z1 and not a D15B7? If it is indeed a Z1, are you sure it's a Y7 distributor that you're bolting up to it?
Old Jun 12, 2009 | 05:28 PM
94EG8's Avatar
Seagull Management
X2. The only thing that will bolt up to a Z1 head is an OBD1 D-series Vtec/Vtec-e distributor.
Old Jun 15, 2009 | 09:24 AM
1SikEagle's Avatar
using the y7 dizzy on a d15z1 long block, 2 bolts line up on the dizzy & head, shouldnt the car still start? or do i have to get a z1 dizzy???
Old Jun 15, 2009 | 11:09 AM
1SikEagle's Avatar
Bump
Old Jun 16, 2009 | 12:11 PM
1SikEagle's Avatar
anybody know?????
Old Jun 17, 2009 | 10:24 AM
1SikEagle's Avatar
anyone?
Old Jun 17, 2009 | 01:15 PM
94EG8's Avatar
Seagull Management
As long as its in the right place it should still start, but you wont be able to set the ignition timing properly without using a Z6/Z1 distributor case.
1SikEagle
Jun 17, 2009 10:49 AM
dohdoh420
Jun 8, 2006 05:54 AM
SupraRXZ
Jan 8, 2006 10:37 AM
IDriveHonda
Jul 8, 2003 07:03 PM
