New valve springs necessary?
Old Jun 10, 2009 | 09:00 AM
99fbpem1's Avatar
Default New valve springs necessary?
I just bought a pair of CTR cams for my b16. Is it necessary that I buy ITR/CTR valve springs to pair them with?
Thanks
Old Jun 10, 2009 | 09:02 AM
93egSLEEPER's Avatar
Default Re: New valve springs necessary?
its not necessary and you should be fine. a stock honda valvetrain will hold stock honda cams
Old Jun 10, 2009 | 02:33 PM
99fbpem1's Avatar
everyone agrees with egsleeper?
Old Jun 10, 2009 | 02:40 PM
FearTheH's Avatar
yes youll be fine
Old Jun 10, 2009 | 04:00 PM
bsmith100's Avatar
I don't think so. Since the type R cams are more aggressive then you should use the type R springs, which I assume are stiffer. You don't want to float a valve due to the increased lift of the type R cams.
Old Jun 10, 2009 | 04:05 PM
yoontim23's Avatar
You will be fine with your stock valve springs and retainer's, but it would be better if you got the ctr/itr valve springs and retainers. Just don't rev it like it's a type r.
Old Jun 10, 2009 | 06:10 PM
FearTheH's Avatar
what about the increased lift of stage 1 and stage 2 cams which do not require an upgraded valve train? type are cams are surely not the equivalent of stage 3 cams. my friend has had CTR cams in his b16a2 with STOCK valvetrain for over 2 years and has not had one single problem.
Old Jun 10, 2009 | 06:38 PM
boostB4beauty's Avatar
From a common sense point of view, i think i would just put in upgraded springs/retainers anyways. They ARE upgraded, therefore should be used in conjunction with other upgraded parts...... I don't think anyone should leave a weak link in the chain. I suggest paying the bucks, picking up some ctr's and just doing the job right.
Then you never have to think about it again. You can rev the **** out of it and not be thinking "man, i should have changed those springs".
Just my opinion...
Old Jun 10, 2009 | 06:53 PM
99fbpem1's Avatar
good point boostb4beauty
Old Jun 10, 2009 | 07:10 PM
bsmith100's Avatar
Yeah if you are going to spend the time and money to get Type R cams you might as well spend a little extra to get the springs. Actually you could probably get Supertech springs for close to the same cost. That way if you decide to go with a more aggressive cam later you won't have to upgrade springs again.
SonicRacing
20
Mar 27, 2009 06:23 PM
LSV_REX
Jun 5, 2005 03:35 PM
klnteg
19
Nov 18, 2003 01:48 PM
Ovl55rag
Oct 17, 2002 09:35 AM
