wHoA! Tranny Problems!!
Old Jun 10, 2009 | 12:11 AM
civic_chaser's Avatar
Default wHoA! Tranny Problems!!
So i've been installing a D16Y8 on my hatch and been running into problems left and right....
I guess my car is in the so called Limp Mode right now cuase the D4 is blinking like crazy. And the CEL code it gave me was P0758 which is shift solenoid B.
First thing I need help with is which solenoid is A and which is B?
Thats the top one.
Thats the bottem one....
It seems as though only 2nd and 4th Gear only want to work. and the motor hits hard when i put it on Reverse Neutral or D4.
Can anyone give me some insight?
I got the top shift solenoid and replaced it already but i dont think that did anything to it cause it feels the same.
I NEED HELP!!!!
Old Jun 10, 2009 | 06:35 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Re: wHoA! Tranny Problems!!
what fluid did you put in?
Old Jun 10, 2009 | 11:01 AM
Well the motor well directly swapped so no fluid was inter-changed. It had the orignial fluid... Im thinkin about doing a complete flush and refill with Honda ATF-Z.
But I still highly doubt that will solve the problem....
Old Jun 10, 2009 | 11:14 AM
TravisCadello's Avatar
replace those cylinders or check all the wiring. maybe a wire got mess up.
And do you have a D1 or D2? if so control the gear through it. start in 1st and shift to 2nd.
You should had made it 5spd.
Old Jun 10, 2009 | 04:50 PM
Im thinkin its the wiring because this guy did a rewiring of the of the transmission harnesses....
But I have another question... doing some research some guy told me that its better to convert my car into OBD1 spec....
What would I require to convert it over to OBD1.
Only thing I can think of is a Z6 Harness, dizzy, and computer.
Can anyone else give me some insight?
Old Jun 10, 2009 | 04:53 PM
Dasfinc's Avatar
Does it even HAVE fluid in it?
If the transmission was transported at all, fluid should have been drained prior to it moving, even if it WASN'T drained, it would have almost certianly coughed up fluid when being pulled out of the car, and low fluid would/will/could cause any kind of transmission issue.
Start by addressing the wiring and CEL to rule out electrical issues, but check the fluid first of all.
Old Jun 10, 2009 | 05:01 PM
Well.. as far as fluid being drained and filled in the tranny... that most certainly happend.. thats what i meant by inter-changed.. sorry. But TY TY yes the fluid is at level with ATF-Z. I dont kno how old but it is in there... the CEL is a P0758, P0135, P0141. The only one im concerned about is the 758. That one is the bad Shift solenoid B.
Which is y i made this post...
DOES ANYONE KNO WHICH OF THE SOLENOIDS ON THE TRANNY IS SOLENOID B????
Old Jun 11, 2009 | 10:02 PM
**BUMP FOR HELP**
Old Jun 11, 2009 | 10:29 PM
r_Senik's Avatar
cliffs: automatic.
no seriously..its because your car is an auto and know one really knows.
i say call a honda tech. they should help you out some.
crystalsky
Apr 17, 2019 04:47 AM
high-octane
10
Aug 27, 2006 11:28 AM
CivicEKCP
14
Dec 23, 2004 02:46 PM
AzntaggeR
Aug 10, 2003 06:38 AM
2000Accord5sp
May 1, 2002 02:41 PM
