*** NEW EAGLE 95MM STROKER CRANK B-SERIES ***
I have 1 new eagle 95mm B-series stroker crank. this crank has all had all the normal problems they come with stock fixed (offset mains lol, improper radius on rod journals, bent etc etc.). I spent about 350 dollars at castillos getting it all back in shape. the crank cost 600 new and add 350 to fix all the problems, making it 950 i have in it. i will sell it for 500 shipped or 450 picked up. im in socal. its a great deal if you want a 95mm crank and dont want to spend an extra 300-350 to have it sorted out. the crank is also balanced.
this crank will go in a b20 block with b16 rods and rs machine pistons for a perfect bolt in fit to make a 2105cc 13:1 monster. easy to build and big hp and tq. makes a b18a/b/c 81mm bore 1955cc. great for budget builds
paypal is omnimanlsr@aol.com
pm me if you need anymore info or have questions that arnt answered.
i also have the forged light weight rods that go with this crank to make your b20vtec a 2105cc motor. the whole thing drops right in with oem pistons.
the 95 mm crank with a b16 rod will drop right in and have the correct deck height and make a 2105cc motor. and still rev to 8k. i have a set of new light weight b16 rods 425 grams each (stock is 530 grams) they will make a very nice stroker setup. just use standard compression height B-series pistons 81-85mm bore. the 2105cc setup is with the b20 block and 84mm pistons. the 81mm bore will be 1955cc.
ill do 750 shipped for the rods and crank together.
paypal is omnimanlsr@aol.com thanks
i also have 2 extra sets of rods if anyone wants them for a b16a. they have press fit pin ends for OEM style cast pistons. i had them custom made so they are very hard to find and a long wait if you make them custom on your own. they are 400 a set and weigh 425 grams each with arp 2000 bolts.
pane93civhb
Oct 16, 2005 08:18 AM
