Problems with GSR swap...
I posted this in the civic forum but thought it would get a few more responses here...
I'm having a problem that I'm hoping can be answered here. I have a 98 Civic Dx. I bought a wrecked 1997 Integra GSR and pulled the motor out of it to put into my civic. I finally got it in and and after doing a ton of research I got all the wiring done. I had some help from a friend who is pretty good at this stuff and has done a few swaps himself. Its my 2nd.
The problem I am having is, the car will idle fine. It seems to be idling a little bit low but I can't actually tell becuase I still have my stock cluster with no tach. (si cluster is on its way) When I give it gas past about 1/4 throttle or maybe even a little bit less it cuts out. It almost seems like it cuts ignition but I'm not sure. I'm not getting any CEL's. I had one before but it was the secondary o2 sensor. It wasn't connected but I've since fixed that and "reset" my ecu.
Any idea's would be greatly appreciated.
andrew dc
Apr 29, 2003 07:11 AM
