ANOTHER cluster problem!
Old Nov 5, 2004 | 05:21 PM
dcb16's Avatar
Default ANOTHER cluster problem!
my cluster works fine for the most part... its only when i accelerate it goes wack. it never did this until i did my swap. the speedo just goes wacko when i punch it. i've checked out the connection and its good... its not the cleanest, but that wouldnt explain the symptoms when i step on it. has anyone ever had this problem? thanks yall
nate
Old Nov 5, 2004 | 08:06 PM
BlueIntegraBoy's Avatar
Default Re: ANOTHER cluster problem! (dcb16)
VSS going out?
Old Nov 6, 2004 | 09:01 AM
dcb16's Avatar
Default Re: ANOTHER cluster problem! (BlueIntegraBoy)
maybe... but i was thinking it was something else, because sometimes when i hit a bump on the freeway, the speedo jumps. ne other suggestions?
Old Nov 7, 2004 | 09:36 AM
dcb16's Avatar
ne one?
Old Nov 7, 2004 | 12:09 PM
2kgs-R's Avatar
I had the same problem after doing my swap, I put a jdm type r motor into my car, which is a 2000 gsr. Everytime I reved the motor up past 6k rpm the rpm would drop back to 0, like it reset. I swapped my stock distributor back in and the the problem went away.
Old Nov 7, 2004 | 11:15 PM
dcb16's Avatar
Default Re: ANOTHER cluster problem! (2kgs-R)
ne one w/ useful info?
blinger
11
Mar 26, 2024 08:08 PM
demonicivis1320
13
Sep 26, 2011 08:26 PM
SetInMotion
Mar 29, 2009 06:05 AM
andrew dc
Apr 29, 2003 07:11 AM
