turbo surge
Old Jun 9, 2009 | 09:47 AM
teg_95's Avatar
Default turbo surge
can someone explain to me what this is and how to get rid of it. and does this sound like a sign. im only boosting 4 pounds right now and my BOV opens at three. so would that cause it to flutter?
Old Jun 9, 2009 | 10:18 AM
TiAL's Avatar
Default Re: turbo surge
sounds more like the turbo is going into surge, the bov has nothing to do with it
Old Jun 10, 2009 | 07:24 AM
teg_95's Avatar
how do you fix/ prevent. and i heard that if the bov flutters that surge
Old Jun 10, 2009 | 07:55 AM
dephtone's Avatar
What kind of BOV do you have?
I know personally I have a Greddy BOV and when I first put it on my car I had terrible compressor surge because the BOV was too tight and not allowing the air from the intake tube to be released once the throttle plate was closed. I had to loosen up the little screw and now it blows off without any issues and no compressor surge.
Compressor surge sounds exactly like you say, it's a flutter sound, it may sound good but it can be very hard on a turbo. Compressor surge happens when the air from the intake side of the piping has no where to go because the throttle plate is closed so it goes back through the piping and goes into the compressor housing actually spinning the wheel backwards which is NOT good. The flutter sound is the air pushing the compressor fins backwards.
Old Jun 10, 2009 | 08:55 AM
ScorpionT's Avatar
Its not surge, and your BOV shouldnt open under 3psi like that. Is it making the noise when youre getting off the throttle or just holding it?
More than likely BOV flutter caused by inconsistent pressures on both sides of the throttle plate.
Old Jun 10, 2009 | 09:56 AM
TiAL's Avatar
which bov, which turbo, how much boost, and when is it doing it? low RPM full throttle?
Old Jun 10, 2009 | 09:49 PM
teg_95's Avatar
its just a no name brand BOV. got it from a friend just to put the kit on. its a t3/t4 and low rpm maybe 3000-3800rpm
Old Jun 10, 2009 | 10:32 PM
b3st0fth3w0rst's Avatar
my .02 i would definitely spend the extra money and get a better BOV, or wastegate; greedy, tial, etc. although cheap no name one work, i've seen more problems with them than top quality ones. no saying the expensive one don't go bad either. a bad BOV/wastegate can ruin your turbo costing you more money in the long run, so u might want to be careful.
Old Jun 11, 2009 | 04:54 AM
teg_95's Avatar
oh yea i am planning to get a better one. just have to wait for the money to be right.
Old Jun 11, 2009 | 06:55 AM
dpetro1's Avatar
fluttering at low psi is most likely not compressor surge. and from your other thread it looks like you arent tuned yet, so stop boosting! i know its tempting but even basemaps can be unsafe in boost
Old Jun 12, 2009 | 08:55 PM
teg_95's Avatar
yea. its goin tuesday
Old Jun 3, 2010 | 04:20 PM
MadeInNewYork87's Avatar
im having the same problem due to over tightening my (HKS)BOV. it was leaking so i tightened it little to see if it would help..
VTECROAR96typeR
Oct 12, 2008 08:39 AM
Beau Gotti
Sep 20, 2005 02:21 PM
ZhaGg
Jul 1, 2004 04:53 PM
CM-R
Jul 27, 2002 09:12 AM
TURBOED-TEG
May 1, 2002 08:00 PM
